December 22, 2024 at 2:04 am
Bahy209815
SubscriberHello ANSYS Community,
I am currently working on an explicit dynamics simulation of an impact test using ANSYS Mechanical (2024 R2). In my setup, I aim to model an impactor striking a slab with fixed support. However, I am encountering an issue where the impactor simply slides through or passes the slab without any noticeable interaction or deformation on the slab.
Model Details:
December 23, 2024 at 8:23 am
mohan.urs
Ansys EmployeeHey,
Why does the model have 2 body interactions ?
In general it should have 1 body interaction set to all bodies by default, since you have 2 simple bodies. If you have made any changes to that - i would suggest you remove one body interaction and for the remaining one scope both the bodies to it.Â
Here is more help on this 3.2. Body Interactions in Explicit Dynamics Analyses
Let me know if this solves the problem.Regards,
Mohan Urs
- Contact stiffness too big
- Test post on Forum – LLM response – SC
- 13-Node Pyramid Element Shape Function
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
4492
1494
1376
1209
