April 27, 2024 at 1:21 am
karthik.remella
AdministratorHello,
I'm having convergence issues on a drop impact simulation on Ansys Fluent. Could you please help?
Thank you!
May 7, 2024 at 2:25 am
Omkar Pawar
Ansys EmployeeHi KR,
It is difficult to gauge the exact reason based on the description provided. There could be multiple reasons why the simulation would diverge, such as mesh, case setup, time step size, etc.
Here are the general guidelines that you could check to ensure they are incorporated in your simulation:
- Solver schemes – Use Implicit.
- Time step size – Use a time step size lower than the one you are currently using in your simulation.
- Primary phase – If it is a closed domain, the primary phase must be a compressible fluid (I assume it would be air in your simulation).
- Ideal gas – If it is a closed domain, enable ideal gas for air.
- The topic ‘Help needed on Multiphase simulation on Ansys Fluent’ is closed to new replies.
- Unable to reopen setup and solution part on ansys workbench
- Ansys Student 2026 R1 – FlexNet Error -88,309 “System clock has been set back”
- How to solve “shell parts that are joined or merged together in their plane” ?
- Ansysのサイトにアクセスできません
- LS-PrePost How to export ICFD StreamLine data for all time states (CSV/JSON)?
