July 15, 2024 at 4:10 am
Daiki Yu
SubscriberHello ANSYS Community,
I'm facing a challenge while installing the ANSYS 2024R1 License Manager and could really use some help. Here’s a summary of the issue:
Situation
During the installation, I edited the Tomcat
server.xmlfile to set up the necessary configurations. However, the changes I made revert back to the original state during the installation process, causing the installation to fail.Log File Highlights
The installation log includes the following warnings and information:
Warnings:
- Unable to set the
compressableMimeTypeproperty. - Warning about using an empty string for
appBaseon thelocalhosthost.
- Unable to set the
Information:
- Details about the Tomcat version, OS, and JVM.
- Information on the deployment of web application directories.
Possible Issues and Actions Taken
Here are some steps I took to troubleshoot the issue:
compressableMimeType Property:
- Ensured the
Connectorelement in theserver.xmlfile includes thecompressableMimeTypeattribute, but the settings revert.
- Ensured the
appBase Setting:
- Checked the
appBaseattribute in theelement of theserver.xmlfile, but it also reverts.
- Checked the
Tomcat Directory Deployment:
- Verified if specific applications or configuration files are correctly placed according to the log details.
TLD Scanning:
- Noted information about TLD scanning in JAR files, but this doesn't seem to be the direct cause of the error.
What I've Tried
- Rechecked the
server.xmlfile to ensure the settings are correct. - Stopped Tomcat, edited the
server.xmlfile again, but the changes reverted during installation. - Restarted Tomcat, but the settings were not applied.
Despite these efforts, the issue persists. If anyone has encountered a similar problem or has any advice on how to resolve this, I would greatly appreciate your input. I can provide more detailed log files and configuration details if needed.
Thank you for your help!
July 15, 2024 at 1:15 pm
George Karnos
Ansys EmployeeÂ
Hello, You should not need to edit any files for a default installation.
Is there a reason that you are editing files?Â
- The topic ‘Help Needed for ANSYS 2024R1 License Manager Installation Issue’ is closed to new replies.
