Heat section simulation in Ansys 19.2 R3
    • timothyy
      Hi, i am trying to modelling a pipe with a heated section. In capture 1, The inlet of the fluid is set to 1 m/s in air and the heated section (green part) is copper at 1000K, and all other parts are at room temperature.  The results in capture 2, however, the temperature spreads all over the pipe, even in the fluid domain, I am not sure what happened in my simulation. I am using Ansys 19.2 R3 and i don't see the timestep selector as the previous version...
Viewing 0 reply threads
  • The topic ‘Heat section simulation in Ansys 19.2 R3’ is closed to new replies.
