November 26, 2024 at 3:22 am
ll00023
Subscribera previous thread discuss the dimension of heat-of-reaction.
https://innovationspace.ansys.com/forum/forums/topic/dimension-of-heat-of-reaction/
see the dimension of Rj/Mj is (mass/volume)/(mass/volume), hj - J/kg, right?
Sh's dimension is J/kg.
in the previous thread, you said, watt is originated from the solver's perspective. I don't understand this.
for a local view, it should be a volumetric result, even for a node. the node value could represent a local volumetric value in reality, right?
another thing you mention is: even though the unit is watt, it actually represents W/m3, right?
the last question is: since the volumetric value is needed here, instead of the value from the point of solver, why ANSYS fluent didn't add the variable directly in the software?
Thank you.
November 26, 2024 at 1:47 pm
Forum ModeratorStuff reacts and heat is released, that will be Watts. But, we may then report that based on cell volume, but in reality we may consider a reactor volume or mass of reactants. Hence you may need to make a distinction between experimental data and Fluent results as in CFD we have different information.
Not sure about the last point.
November 26, 2024 at 7:11 pm
ll00023
SubscriberI found a source of the heat-of-reaction dimension.
So the heat of reaction variable does show the result based on volume (W/m3). Is this an inconsistency?
since I need to eliminate mesh's impact on the result, is mesh independent test enough for me to say : heat of reaction is not affected by mesh size, just like temperature?
or how to eliminate it in other ways?
you hit the point: the distinction between experimental data and Fluent results.
heat of reaction is Fluent results; why Fluent does not include the variables for experimental data directly?
I need to study the concepts of reaction and heat release further to understand you better.
Thank you.
November 27, 2024 at 10:24 am
Forum ModeratorMesh resolution/independence will ensure you capture the species, thermal and flow field & gradients. That in turn resolves the heat of reaction accuracy.
CFD and experiment are different. In an experiment I may know I've released 160W, I can get that from CFD but I can also find where that heat was released within the domain. Both are useful.
5824
