October 20, 2024 at 2:31 pmSushantSubscriber
Is it possible to create a frictional contact in bodies, which will not allow seperation of contact between any load steps. Once frictional contact is created is should not seperate.
If above is not possible, then can we give friction in No seperation contact
October 21, 2024 at 11:51 amHarshvardhanAnsys Employee
I am not sure if what you are asking is possible in Workbench.
Not allowing frictional contact to separate goes against the real world definition of a frictional contact between two bodies. Also, No Separation contact is a linear contact, therefore friction cannot be defined for it. (Frictional contacts are nonlinear by nature.)
Maybe other forum members have some insight on this.
Harshvardhan
Ansys Innovation Space
- Ayuda con Error: “Unable to access the source: EngineeringData”
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Frictional No separation contact
- Elastic limit load, Elastic-plastic limit load
- Script Error Code:800a000d
591
569
525
366
