October 21, 2024 at 5:12 pm
dab00004
SubscriberI have previously installed Ansys 2023 R1 for my class last year and the license expired so I uninstalled it and installed 2024 R2. When trying to run a simulation, I get an error saying there was an issue with the flexnet publisher. I figured this may be an issue with some of the old licensing files from the previous version not properly being erased so i installed it onto my laptop instead which has never had ansys and it worked just fine. Is there any solution to this? My next step would be to install windows again to completely wipe my drive and any hidden files that may be lingering from the previous install. Also I recieved 2 different whybad parameters after running the license manager as administrator. Before running it, it showed whybad = -5 and after it shows why bad = -88309.
Any help is appreciated! Thank you.
October 22, 2024 at 11:30 am
George Karnos
Ansys EmployeeHello,
I recommend to try the following:
Uninstall.
Rename the c:\Program files\Ansys Inc directory to Ansys.Old
Rename the %APPDATA%\Ansys\v242 directory to v242.old
Reinstall by right-clicking on setup.exe and choosing more->"run as administrator" -
November 28, 2024 at 8:32 pm
AntKou01
SubscriberÂ
I have had the same problem, but i have unistalled previous ansys versions and deleted the related files from the system (meaning C:\Program Files\Ansys). I had the 2022r2 working on Mechanical APDL then the licence expired, I installed the 2024r1 for FLUENT which worked fine, but then working on FORTE I had that FNP licence error. I uninstalled it and removed the relevant files and reinstalled 2024r2 with the same error appearing even on the FORTE .ftsim tutorials (by the way on 2024r2 FLUENT works fine). Is there a posibility that there are variables in the system or files located somewhere else that must be deleted or renamed, because they conflict with the fromerly installed program? And if so what could i do?
Kind regards, and thanks a lot.Â
November 30, 2024 at 4:31 pm
AntKou01
SubscriberÂ
Hello again,
I tried the process mentioned above, but the same error in forte occurs.
ANS_LogErrorMessage: Caption: ANSYS LICENSE MANAGER ERROR
 Error: No FlexNet Publisher (FNP) license found for feature CFD Base.
      FNP license path: C:\Users\\AppData\Local\Temp\\012e05fc-bd9b-41fd-88d9-e82df7c6382dHow should i proceed?
Thanks again!
PS: I have installed again the student version 2024r2.1 from the same zip i installed it the last time.
- acces to path ‘session_files’ is denied error
- unexpected license problem; exiting. hit return to exit.
- critical error during installation of 24 R2 version
- No FlexNet Publisher (FNP) license found for feature HPC Parallel.
- Ansys Electronics Desktop crashes when trying to set the steel type in RMXprt
- Can not find Spaceclaim option in ANSYS2024R2 workbench
- Workbench application not showing up after installing Ansys Student 2024 R2
3029
971
858
841
777
