October 9, 2024 at 9:33 am
deshpandegayatri45
SubscriberI am having trouble during the installation of the software. The prompt says critical error, later on, it says instcore.exe not responding. The installation was 90% completed once, but in the progress log it said "RSS is disabled". When I started installation, I had not uninstalled the 23 version so eventhough, the installation was complete, I couldn't run the software. Hence I uninstalled the 24 R2 software and then I uninstalled the 23 version. Now I have tried installing and uninstalling the 23 version and installing the 24 R2 version but it stills gives the same prompt with the same error.
October 10, 2024 at 3:17 am
GiRi
SubscriberI faced similar issue, installing 24 R2. Turns out, it was the Avast anti-virus software that was conflicting with the installation. Turning the antivirus shields off resolved the issue.
April 30, 2025 at 10:53 am
mohmdkm05
Subscriberdid u find out what is the solution ,seems like im facing the exact same problem
- acces to path ‘session_files’ is denied error
- unexpected license problem; exiting. hit return to exit.
- critical error during installation of 24 R2 version
- No FlexNet Publisher (FNP) license found for feature HPC Parallel.
- Ansys Electronics Desktop crashes when trying to set the steel type in RMXprt
- Can not find Spaceclaim option in ANSYS2024R2 workbench
- Workbench application not showing up after installing Ansys Student 2024 R2
3024
971
857
815
777
