September 28, 2020 at 2:52 pm
JASOMCHANG
SubscriberI would like to ask you how to designate a point on a moving object in the post-processing of the fluid, and use this point to measure the parameter change of the object in motion.
As shown in the picture, I want to fix several points on the fin to measure the pressure value that the fin changes at different times.
September 28, 2020 at 3:38 pmRob
Forum ModeratorI don't think you can, others may know a way. Simple option will be to split out one facet on the surface and monitor that. nViewing 1 reply thread- The topic ‘Fluid post-processing measurement problems’ is closed to new replies.
4934
1638
1386
1242
