February 3, 2024 at 12:48 pm
aditi garg
SubscriberDear Community,
I am currently working on a CFD simulation of a Compound Parabolic Collector (CPC) solar collector with conjugate heat transfer. The model consists of a receiver tube enclosed between parabolic reflectors and a rectangular glass cover at the aperture of the CPC. Water flows through the tube, and air surrounds it inside the enclosure. The figure for the model has been shared in the attachment.
Copper receiver Tube is geometrically given a thickness of 1mm in space claim. While modelling them in space claim, shared topology was also applied. So there are 2 fluid zones (air and water) and one solid zone (copper) in the model.
In fluent, sets of wall & wall-shadow are obtained each for air-copper and copper-water interfaces.
I have encountered a warning message in Fluent that appears during the mesh reading process.
The warning states:
"Warning: materials in neighbor cell threads (6 and 7) of interior zone 4 are of different types (water-liquid and copper). This problem MUST be fixed before solving!
Warning: materials in neighbor cell threads (7 and 8) of interior zone 5 are of different types (copper and air). This problem MUST be fixed before solving!"
This message is repeated 55 times in the console.
Subsequently, Fluent performs mesh operations such as "Change Zone Type" and "Slitting wall zone," creating shadow zones for the interfaces between air-copper and copper-water.
The following messages are displayed in console for such mesh operations performed.
Applying mesh operation "Change Zone Type" Slitting wall zone 5 into a coupled wall.
creating receiver_air_side-shadow Applying mesh operation "Change Zone Type [ 2 ]"
Slitting wall zone 4 into a coupled wall. creating receiver_water_side-shadow
Applying mesh operation "Change Zone Type [ 3 ]" Setting zone id of fff-1-copper_tube to 7.
Setting zone id of fff-1-water to 6. Setting zone id of fff-1-air to 8.
So on and finally
“Preparing mesh for display...
Done.”
Despite these warnings, my simulations are running smoothly, with convergence observed in terms of residuals, steady-state conditions, and consistent physical quantities such as receiver outlet temperature and heat flux.
I am reaching out to seek your expertise on whether these warnings pose a significant issue.
I am uncertain about the implications of these warnings and whether any corrective actions are necessary.
I have gone through various discussions on similar topics within this platform, but I am still seeking a clearer understanding of the steps that can be taken to address or eliminate these warnings.
Your valuable insights and guidance on how to interpret and potentially resolve these warnings would be greatly appreciated. Thank you for your time and assistance.
February 5, 2024 at 1:38 pm
CFD_Friend
Ansys EmployeeHi Aditi,
For conjugate heat transfer cases, it's normal for Fluent to slit a wall to shadow zone and then couple them together. Please see these learning materials, they might give an insight.
February 7, 2024 at 5:40 pm
aditi garg
SubscriberHello CFD_Friend
I understand about the conjugate transfer part and the shadow zone. My fluent file has these shadow zone for the wall having conjugate heat transfer.
The problem is :
Say i want to change the element size in mesh file, so I change the size, generate the mesh and update it.
now I run the fluent which is now reading the updated mesh, so in console of fluent that warning message is displayed.
. Now, if i reset the fluent (deleting all previous settings done in fluent) and read the updated mesh, this warning does not appear.
it solves the problem, however, it takes a lot of time and effort to again setup the fluent for every refined mesh case.
- The topic ‘FLUENT:Warning:materials in neighbor cell threads of interior zone different typ’ is closed to new replies.
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Script Error
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- convergence issue for transonic flow
- Running ANSYS Fluent on a HPC Cluster
- Point exception in erosion calculation
1932
823
599
591
366
