September 25, 2023 at 8:25 am
lee ann
Subscriber我在瞬态分析中画好网格之后将其导出为.msh格式的网格,然后导入到fluent中计算温度,最终导出的表面的温度数据的数量和瞬态中导出的表面数据的数量不一致,请问问题出在哪里
September 27, 2023 at 9:25 am
Essence
Ansys EmployeeHello,
I have understood your question as follows: "I drew the mesh in transient analysis and exported it to .msh format, then imported it to fluent to calculate the temperature, the number of temperature data of the final exported surface is not consistent with the number of surface data exported in transient, what is the problem?". Please correct me if I am wrong.
What do you mean by "number of temperature data of the final exported surface"? Could you please elaborate?
September 28, 2023 at 4:30 am
lee ann
Subscriber从fluent中计算得到零件的温度数据,按照表面节点进行导出,导出的节点的数量
- The topic ‘fluent流体仿真和workbench的瞬态分析能否使用同一个网格模型’ is closed to new replies.
1890
1419
