September 22, 2023 at 8:24 amMargherita DottiSubscriber
I wrote an UDF that is supposed to read some profiles from a .csv file.
But it appears that the fuction does not loop through the several rows of the file.
It just keeps reading for N_total times the first row.
Does anyone know how do I fix this?
BR,
Margherita
Just in case, the data within the .csv file looks like this:
September 22, 2023 at 12:53 pmFedericoAnsys Employee
Hello,Â
what does MY_INPUTS look like? do you have "\n" at the end of the format?
September 25, 2023 at 10:37 am
- The topic ‘Fluent UDF to impose profiles from a .csv file’ is closed to new replies.
Ansys Innovation Space
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- convergence issue for transonic flow
- RIBBON WINDOW DISAPPEARED
- Running ANSYS Fluent on a HPC Cluster
635
599
591
366
