December 12, 2024 at 3:12 amjackhc0609Subscriber
Does mesh generation software (such as Fluent Meshing) support directly inputting a target y+ value to automatically calculate the mesh height or auto mesh?how to?
December 12, 2024 at 8:31 amSRPAnsys Employee
Hi
Fluent Meshing does not have a direct input feature for a target y+ value to automatically calculate the mesh height. However, you can estimate the first cell height (y) for the mesh from the desired value of y+ using known parameters. You check KM for more details: How to estimate the first cell height (y) for the mesh from the desired value of y plus (y+)? | Ansys Knowledge
Ansys Innovation Space
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Script Error
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- convergence issue for transonic flow
- Running ANSYS Fluent on a HPC Cluster
- Point exception in erosion calculation
802
599
591
366
