January 11, 2025 at 3:14 pm2352859601Subscriber
Simulating the washing process of a drum washing machine uses a multiphase flow method to set the drum rotation. How can this be resolved? Additionally, in coupling simulation with Rocky, can the simulation objectives be achieved by adding flexible particles in Rocky while setting the same rotation speed?
January 13, 2025 at 9:58 amRobForum Moderator
If the domain is just rotating you can use sliding mesh: dynamic is for when you need to change the shape of the domain. That may resolve part of the problem. You also need to check up on your porous zone: read the red text.Â
Ansys Innovation Space
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Script Error
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- convergence issue for transonic flow
- Running ANSYS Fluent on a HPC Cluster
- Point exception in erosion calculation
802
599
591
366
