Ansys Products
Ansys Products
Fluent doesn’t start
    • Arunkumarmoovandan37
      Everything works finenBut fluent says 'fluent failed to start'.nBoth standalone and workbenchnBut when i use c:\program files\ansys inc\v191\fluenttbin\win64\fluent.exe in the cmd prompt It opens.n
      What does the Standalone launcher point at, all that's doing is use the command. n
      When I try to open fluent through workbench it says fluent failed to start.nBut when I use that command it opens.n
      And using stand alone from the Start menu icon?n
      That also doesn't opennBut when I use this in the command prompt c:\program files\ansys inc\v191\fluenttbin\win64\fluent.exen
      If you check the properties of the launcher what do you see?nIs R19.2 on my laptop. n
      Nothing different same as yours.nn
      Which version are you trying to launch? The command line you gave is R19.1 but the panel in the image you posted is R19.2 They're different installs so please check what is and isn't installed and which versions you're trying to launch with each method. n
      It is 19.2 not 19.1nn
      If you use the command line that's R19.1 but the icon is pointed at R19.2 You can have both installed, but if the University licence manager is R19.1 then R19.2 will fail to launch. n
      No I've installed only r19.2nThere's no other ansys versions installed in my pcn
      OK, and the command line you're using to launch Fluent is c:\program files\ansys inc\v192\fluenttbin\win64\fluent.exe ? n
      Yesn
      After whole pc reset it works finen
Viewing 13 reply threads
  • The topic ‘Fluent doesn’t start’ is closed to new replies.
