December 20, 2018 at 12:16 pm
PDCoy
SubscriberHello:
I'm working on a CFD project at my university using Fluent. I'm having serious troubles with fluent due to the fact that, once I've upgraded the mesh, Fluent doesn't get that mesh and stills working with the previous one. Sometimes Fluent asks if I want to get the new mesh, but sometimes it doesn't. I've been trying to sove that problem, but I have no more ideas.
Could anybody help me?
Thanks.
December 20, 2018 at 3:12 pm
Forum ModeratorIf you're pulling a mesh in from Workbench Meshing it ought to be automatic. If not check the ribbon tool bar in Fluent and see if there's an update. Note, if you change topology or labels it can cause problems. Also, if you've done adaption or are using non-conformal interfaces the update may fail.Â
December 20, 2018 at 6:35 pm
December 21, 2018 at 4:37 am
December 21, 2018 at 9:05 am
PDCoy
SubscriberSometimes it works, but not allways. I mean, I allways update the mesh, but sometimes it seems to be updated (a tick is shown in mesh). Then, I click "update", but Fluent doesn't show the message that advices that there's a new mesh. When I start Fluent, the mesh didn't changed.
December 21, 2018 at 9:14 am
Keyur Kanade
Ansys Employeeif you update mesh then set up cell does not show green tick mark. if you try to open set up cell it asks you if you want to update mesh in set up.Â
December 21, 2018 at 9:21 am
PDCoy
SubscriberThat's the problem. Set up stills showing the tick mark once the mesh has been successfully updated. The mesh has changed, but Fluent doesn't change. Furthermore, Fluent loads the former mesh.
December 21, 2018 at 9:26 am
Keyur Kanade
Ansys Employeedid you update mesh?
please post image of mesh before and after update. also please post image of workbench project page before and after update mesh.Â
did mesh cell show lightening sign before update?Â
December 21, 2018 at 9:55 am
PDCoy
SubscriberI can't post images because of the fact that today its working right. Yesterday was different. When I changed the mesh, the lightening sing wasn't shown. I don't know why sometimes it works and sometimes it doesn't. Could my OS be the problem? Or any software? I don't know what's wrong.
December 21, 2018 at 10:27 am
PDCoy
Subscriber -
December 21, 2018 at 10:35 am
Forum ModeratorHave you got a green tick to all components within the meshing tool?Â
December 21, 2018 at 11:04 am
December 21, 2018 at 1:48 pm
Keyur Kanade
Ansys Employeesuppress that line body and check again.Â
December 21, 2018 at 2:54 pm
PDCoy
SubscriberIt worked.
Thank you!
December 31, 2018 at 11:04 am
PDCoy
SubscriberHello.
After a few days working, problems are back. Although I've supressed the linear body, a question mark appears after meshing. It also can't be upgraded and, when I open the mesh, it seems to be empty. I'm wondering if there's any problem with my student license because the original problem stills there (Fluent doesn't get the upgraded mesh).
This is my screen after meshing.
When I open mesh:
Thanks.
- The topic ‘Fluent doesn’t get upgraded mesh’ is closed to new replies.
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Script Error
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- convergence issue for transonic flow
- Running ANSYS Fluent on a HPC Cluster
- Point exception in erosion calculation
1932
823
599
591
366
