TAGGED: #fluent-#ansys, #fluent-#cfd-#ansys, ansys-fluent, ansysfluent, fluent
April 5, 2024 at 3:27 am
mmnyako
SubscriberI am trying to do a heave and roll decay test in calm sea conditions, how do I model the velocity inlet, pressure outlet, and walls boundary conditions for a calm sea state.Â
April 5, 2024 at 12:26 pm
Forum ModeratorYou could use open channel, or possibly even bound the domain with walls (pressure bc for the "sky") depending on how far the walls are from the object.Â
April 5, 2024 at 2:06 pm
mmnyako
SubscriberThanks for the response Rob,
1) In the case I use open channel flow as you suggested, the velocity magnitude at the inlet should be zero right?Â
2) How can I, then, create a report definition that plots roll and heave decay with time, Just as in the heave decay image below?
   My simulation is on a Spar cylinder hull seen in the image below, any suggestion will be appreciated. thanks!
April 5, 2024 at 2:22 pm
Forum ModeratorZero flow is fine. Note, the D in CFD is Dynamics so you may find converge (residuals) to be relatively poor - also review what the residuals represent.Â
Have a look at the surface reports for mesh; you may not have an easy angle report but min/max may be sufficient? Unless the UDF for 6DOF can return something?Â
April 5, 2024 at 2:36 pm
mmnyako
Subscriber"surface reports for mesh"
Please can you elaborate, Is that how I can create reports plot for the roll and heave? -
April 5, 2024 at 2:43 pm
Forum ModeratorHave a look at the Report Definitions in the Fluent solver tree. They're used in most of the tutorials so you'll find examples there.Â
April 5, 2024 at 4:34 pm
April 5, 2024 at 2:51 pm
mmnyako
SubscriberOkay thanks, I'll have a look.
April 5, 2024 at 7:45 pm
April 8, 2024 at 8:56 am
Forum ModeratorTry it and see if it's what you want/need.Â
- The topic ‘Fluent Calm Water Conditions for decay test’ is closed to new replies.
5719
