July 31, 2020 at 8:05 pm
Karthik Remella
AdministratorHello everyone,
I have a question regarding the animation files in Fluent. While I am working on a local machine, the resolution and position of elements on the picture files are right but when the simulation is carried out on the Cloud, the resolution is downgraded, the scene gets limited and the scale changes its place. I understand the limitations of the graphic abilities of the cloud calculations, but is there any way to set up good quality animations from cloud calculations through GUI?
Thanks
July 31, 2020 at 8:06 pm
Kalyan Goparaju
Ansys EmployeeHi,
I'm seeing the same thing when exporting .jpeg from solution animation. I think exporting .hsf files for the solution animation would be a better alternative. This is a 3d visualization file type that will allow you to change the orientation and zoom after the run. There are two options for using the .hsf files.
1. You can download the .hsf files and the .cxa file and create the animation on your local machine by loading the .cxa into the Animations Playback as shown in the image.
2. Use the RDP Postprocess option to set up the animation playback on the Cloud.
Thank you.
February 2, 2021 at 7:53 am
Khaled_Mohamad
SubscriberI have the .hsf files without the .cxa nCan i perform the animations?n -
November 17, 2022 at 8:43 am
akhilsnt
SubscriberAs you discussed (Kalyan Goparaju), You can download the .hsf files and the .cxa file and create the animation on your local machine by loading the .cxa into the Animations Playback, as shown in the image.
I could not see any image.
Can you help me how to convert the .hsf file or .cxa file to video (.avi file)
September 16, 2023 at 1:09 am
Yvette Law
SubscriberI make an autosave for one .cxa file and .hsf file from time to time.
Does anyone can explain how to convert the .hsf file or .cxa file to video (.avi file)
- The topic ‘Fluent animation files’ is closed to new replies.
6410
