Floating Point Exception
    • sgpsaiz
      In Ansys Fluent 2024 R1, I'm performing a CFD of a hydrocyclone to try and obtain the pressure drop, but when I increase the velocity of the inlet to 1.6m/s and try to run the calculation, I get the following notification;
      Error at host: floating point exception
      Error: floating point exception
      Error Object: ()
      Error at Node 0: floating point exception
      Error Object: #f
      I don't get this notification when I'm running the calculation with a lower velocity like 0.1m/s. It only happens when I increase the velocity. Please help, thank you.
    • Federico
      Check your mesh quality.
      If running transient, check the time step size, which may need to be reduced if increasing velocity.
    • sgpsaiz
      I checked the mesh and reduced the time step size to 0.5s, but I'm still getting the same error.
    • Federico
      how does a time step size of 0.5s compare to your mesh? Think of a Courant condition for stability V*dt/dx
    • sgpsaiz
      I'm not running transient and I have checked the mesh quality and I'm still getting the same error.
      • Federico
        What is the reported mesh quality?
      • Federico
        Also, when does it fail?
        Upon initialization? Or does it run for a bit before throwing this error?
    • sgpsaiz
      It happens upon initialization.
      Image preview
Viewing 5 reply threads
