Ansys Products
Ansys Products
Fatal error while simulating on Ansys Maxwell!!
    • mohitegd
      while running the pmsm simulation on the electronics suite using maxwell i am facing this issue in which software doesn't response and the file gets converted into the zip file and the data gets lost . after several times the software collapses and starts showing fatal error.
    • Timotheos Fetsis
      Hi, this is an issue that will be fixed in 2025R1 version. Please use either 2024R1 or a previous version so that you successfully create the RMxprt design.
