December 4, 2023 at 7:29 pm
December 6, 2023 at 10:00 am
Rajeshwari Jadhav
Forum ModeratorHi Dimitris,
Can you check if there are any errors logged in the event viewer. Start>event viewer> expand windows log and click on Application.
December 6, 2023 at 2:45 pm
Dimitris Plaskasovitis
Subscriber☝
December 6, 2023 at 2:37 pm
December 6, 2023 at 2:42 pm
Rajeshwari Jadhav
Forum ModeratorDouble-click on errors and send the screenshot.
December 6, 2023 at 2:47 pm
December 6, 2023 at 2:49 pm
December 6, 2023 at 2:56 pm
Rajeshwari Jadhav
Forum ModeratorCheck the PATH System Variable to make sure that C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;… entries are in front of everything else.
Like: PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;…all other entries...
Manually register the DLLs listed below by starting a Command Prompt (DOS) "as administrator" and changing to the directory c:\windows\system32, then typing:
regsvr32.exe ole32.dll
regsvr32.exe atl.dll
regsvr32.exe oleaut32.dll
regsvr32.exe scrrun.dll
regsvr32.exe jscript.dll
regsvr32.exe vbscript.dll
- Update Windows
- Click Start button, and look for Control Panel.
- Click System and Security, and select Windows Update.
- Click Check for updates and click Install updates.
Rename the Ansys folder to Ansys.old (type %appdata% in start menu), relaunch the application.
February 19, 2024 at 5:36 pm
Wahsay Waseem
SubscriberHi,
After completing the steps, the error persists. Any further ideas to solve this problem?
- The topic ‘Fatal Error Ansys- Unhandled Exception Caught’ is closed to new replies.
5934
1306
.png)
.png)
.png)
.png)
