November 19, 2024 at 7:44 pmFarahSubscriber
Hi
I set up a two-way FSI in ANSYS 2024R2 and in the last module (System Coupling) once I click it I receive this error message :
Failed to initialize any rendering context, please ensure you have a supported graphics accelerator installed with ANSYS certified drivers or that you are using a supported remote display solution
And after a second I start receiving below error messages
Do you know what could be possible reason behond it?
November 20, 2024 at 1:47 pmGeorge KarnosAnsys Employee
What is displayed if you click on "Show details" in the first error?
What Graphics card is installed in your system?
Does any Analysis system work?If supported graphics card, have you updated the drivers for the card?
Ansys Innovation Space
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Cyclone (Stairmand) simulation using RSM
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- convergence issue for transonic flow
- RIBBON WINDOW DISAPPEARED
635
599
591
366
