Student Competition
Student Competition
Topics related to vehicle design, sponsorship, application process etc.
Failed to generate surface mesh
    • tr760256
      I ran into this error when generating surface mesh for our FSAE car
      I've already checked the geometry and do all the repair and prepare steps, share topology for it. For fluent, I already did the sizing and pretty sure that I've applied correct sizing to capture everything. I've also read and do everything that this is recommended in this link  https://innovationspace.ansys.com/forum/forums/topic/fluent-meshing-error-3/.
      Can anyone help me fix this problem?
    • Hemant Gurav
      Please review the sidewing part of your geometry. There might be some hanging nodes or unwanted surfaces that you may need to remove manually. Could you share a screenshot of your geometry?
    • catherinebrooke156
      It can be frustrating when a surface mesh fails to generate. If you are facing challenges like this in your projects, consider seeking PGCE Assignment Writing Help to manage your workload and improve outcomes.
    • lbp40357
      You can double-check the mesh settings for any inconsistencies, such as element quality or mesh size variations, and consider refining the mesh in critical areas or using a different meshing method to see if that resolves the error. slope
