October 13, 2025 at 10:01 am
hndoli002
SubscriberI'm simulating the axial crushing of a tube in ANSYS LS-DYNA Mechanical (2025 R2 Teaching license). While the analysis is working very well, I can't get reaction forces on either side of the tube.
The setup I'm using consists of a plate as an "anvil", the axial tube, and a block as a "hammer", which has velocity and gravitational conditions applied. To calculate the energy absorbed by the deformation, I need to integrate the force over the deformation of the tube. I can easily get data for how much the tube has deformed from the displacement of the 'hammer', but I'm having difficulty getting the force of the hammer on the tube. I would usually measure this between the tube and 'anvil' plate. If I explore Results →Worksheet, it appears that forces are not a user-defined result that I can directly get.
Is there a way of getting reaction forces on the supports on the plate, or of getting the contact force between the tube and plate directly? At the moment I'm getting the average pressure across the surface to calculate the force, but this is not seeming quite accurate - or should it be?
October 13, 2025 at 10:38 am
Nanda
Ansys EmployeeHello User,
Please refer to this forum thread: Force reaction in LS-Dyna workbench
Let us know if you need more help.
Nanda.
Introducing Ansys Assistant a 24/7 AI-powered virtual assistant for active Ansys academic customers.
Have a look at our public help documentation website: Ansys Help
For more exciting courses and certifications, hit this link: Ansys Innovation Courses | ANSYS Innovation Space
October 13, 2025 at 12:12 pm
hndoli002
SubscriberHi Nanda,
Thanks, that worked perfectly! It also helped with my problem of the time stepping of the results, so that has been sorted out.
Kind regards,
Oli
4102
1487
1318
1156
