October 19, 2023 at 1:12 pm
October 20, 2023 at 4:20 pmmrifeAnsys Employee
Emporer
Check the Ansys Mechanical APDL Help on Contact174; the friction coefficient, MU, is an result and is stored in NMISC items, one item for each corner node of the element. You can use a User Defined Result with the expression NMISCxx where xx is the specific number you will find in the help for the result. And scope to the contact.
- The topic ‘Evolution of frictional coef’ is closed to new replies.
Ansys Innovation Space
- Speed up simulation in HFSS
- Workbench license error
- ansys fluent error when opening it “unexpected license problem”
- Unexpected error on Workbench: Root element not found.
- not able to get result
- Unable to recover corrupted project in Workbench
- Unattended (silent) installation of 2024R2 & -productfile switch
- Unexpected issues with SCCM deployment of Ansys Fluids and Structures 2024 R1
- Questions and recommendations: Septum Horn Antenna
- AQWA: Hydrodynamic response error
513
488
225
209
