November 7, 2020 at 1:31 pmCongestedHangmanSubscriberwhen i create a beam (say I-beam) in SpaceClaim using the beam profile in prepare tab, the beam remains transparent. without manually drawing, can i turn it to a solid shape if i use the beam profile? if i export the beam in other format (.obj) it's literally empty. [pic 1]nn
November 7, 2020 at 1:54 pm
- The topic ‘Everything about Beam’ is closed to new replies.
Ansys Innovation Space
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Frictional No separation contact
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
- Element has excessive thickness change, distortion, is turning inside out
599
591
565
366
