November 6, 2018 at 9:21 am
JarHead
SubscriberCan anyone guide me how to plot Odd and Even mode impedances of a 4-port microstrip directional coupler. Driven Terminal Modal
November 16, 2018 at 2:38 pm
Karthik Remella
AdministratorHello,Â
Quick question - which tool are you using for your analysis?
Thank you.
Best Regards,
Karthik
November 17, 2018 at 5:47 am
JarHead
SubscriberKarthik I am using HFSS 15.0
December 7, 2018 at 10:36 pm
3Asif
Subscriber Hi JarHead,
I am not tried this method to compare but you can try this suggestion and verify it against known value, to see if it works:
Set solution type: Driven terminal
Draw two terminal lines while creating waveport.
Set differential ports (Right click on the excitation and set proper pair). Your 50Ohm ports will be then 100Ohm for diff, and 25 Ohm for common.
Run sim, and thenÂ
Zeven= 2*Zcommon
Zodd=Zdiff/2
Thank you, -
September 17, 2020 at 3:08 pm
hamzaabbaskiani91
Subscriberhave you tested the solution mentioned ? n
Viewing 4 reply threads
- The topic ‘Even Odd Mode impedance’ is closed to new replies.
1313
