January 11, 2024 at 3:28 pm
mohammedlaminemekhalfia
SubscriberDear
I have the following error when I try to analyze the model :Â
  [error] This design cannot be solved using TDM (Time Decomposition Method).  This is because this design may include models using hard hysteresis, coreloss effect on field, additional core loss due to normal flux, object-based loss output, impedance boundary or motion setup using 'consider mechanical transient'. And the current version of TDM does not support models using adaptive time stepping, or models using external circuits with unsupported circuit elements: solution-dependent switches, diodes and capacitors.Also, TDM does not support stop and continue from serial solving to TDMÂ
I resolved the model before and I did not face this error, the project was validated correctly.
January 12, 2024 at 7:01 pm
GLUO
Ansys EmployeeHello,Â
Please go to Setup>>HPC options>> Edit>>Job Distribution to turn off TDM (uncheck transient solver).
GL
January 15, 2024 at 9:34 am
Timos
Ansys EmployeeHello, it is possible that you didn't analyze your model with TDM (Time Decomposition Method) before. This is the reason you didn't encounter any errors.
However when solving with TDM there are several factors that you should take into consideration. For example your model should not contain any impedance boundaries. The same is for the other options that the error shows.
- The topic ‘errror with Maxwell3D Transient’ is closed to new replies.
5874
1306
