October 18, 2021 at 10:20 am
blue_nun_7
SubscriberHi There,
I am having a problem connecting Maxwell to Simplorer via cosimulation. In my case the problem is a little bizarre. I had the co-simulation running with no problems. Then, without changing anything (so far as I know), it threw up an error. I went back to some old model files which previously ran successfully, and they throw up the same error! Errors are below. It is frustrating - I have uninstalled and reinstalled software, and have rebuilt model from scratch - but no success. Both models run fine on their own. I wonder whether it is to do with ports? The error seems to be with the FEA component in Simplorer, which has a 'Maxwell_HostPort' of 7778. But really I have no idea - I cannot understand why it worked, and now doesn't.
Any ideas much appreciated :)
PMV19 (F:/)
 Max (Transient)
  [info] Verify conduction path: Conduction path validate success. (11:13:03 AM Oct 18, 2021)
  [error] Total memory is not enough for TDM. (11:13:10 AM Oct 18, 2021)
  [error] Simulation was aborted by user on server: Local Machine. (11:13:11 AM Oct 18, 2021)
 Simp
  [info] Compilation... (11:13:05 AM Oct 18, 2021)
  [info] Compiler completed successfully. (Time = 1 sec) (11:13:07 AM Oct 18, 2021)
  [info] Analyzing... (11:13:08 AM Oct 18, 2021)
  [error] [Sim2000] Error - FEA1: We should not be receiving 0 byte data. >> Initialize (11:13:09 AM Oct 18, 2021)
  [error] [Sim2000] Error 11557 - Error encountered in the Simulate function of user model. Model: FEA1.MAXWELL
 >> Initialize (11:13:09 AM Oct 18, 2021)   [error] [Sim2000] Error 13431 - Fatal error encountered while updating models. Model: FEA1.MAXWELL
 >> Initialize (11:13:09 AM Oct 18, 2021)   [error] [Sim2000] Error - Error while updating model values and states. >> Initialize (11:13:09 AM Oct 18, 2021)
  [error] [Sim2000] Error 10523 - Error encountered while initializing the simulators. >> Initialize (11:13:09 AM Oct 18, 2021)
  [error] [Sim2000App] Error 10533 - Error encountered during INIT. >> Initialize (11:13:09 AM Oct 18, 2021)
October 21, 2021 at 5:12 amNavya Chode
Looks like there is not enough memory.
Turn off any TDM settings under HPC settings in Maxwell.
Regards Navya
October 21, 2021 at 9:43 amblue_nun_7
Subscriberthanks for your response. I changed HPC Options - Options - HPC License to 'Pack' to avoid use of TDM. However, main errors are still there. It seems to fail on the Simplorer FEA1.Maxwell model, which is the cosimulation component in Simplorer. If you look at the timing, the first failure in Simplorer happens a second before the error in Maxwell. The first and main error is in Simplorer:
[error][Sim2000]Error - FEA1: We should not be receiving 0 byte data.
This seems to suggest that Maxwell is not sending data to Simplorer. Any thoughts?
Maxwell3DDesign1 (Transient)
[info] Verify conduction path: Conduction path validate success. (10:17:40 AMOct 21, 2021)
[error] Simulation was aborted by user on server: Local Machine. (10:17:58 AMOct 21, 2021)
Simplorer1
[info] Compilation... (10:17:41 AMOct 21, 2021)
[info] Compiler completed successfully. (Time = 2 sec) (10:17:44 AMOct 21, 2021)
[info] Analyzing... (10:17:44 AMOct 21, 2021)
[error][Sim2000]Error - FEA1: We should not be receiving 0 byte data.>> Initialize(10:17:57 AMOct 21, 2021)
[error][Sim2000]Error 11557 - Error encountered in the Simulate function of user model.Model: FEA1.MAXWELL>> Initialize(10:17:57 AMOct 21, 2021)
[error][Sim2000]Error 13431 - Fatal error encountered while updating models.Model: FEA1.MAXWELL>> Initialize(10:17:57 AMOct 21, 2021)
[error][Sim2000]Error - Error while updating model values and states.>> Initialize(10:17:57 AMOct 21, 2021)
[error][Sim2000]Error 10523 - Error encountered while initializing the simulators.>> Initialize(10:17:57 AMOct 21, 2021)
[error][Sim2000App]Error 10533 - Error encountered during INIT.>> Initialize(10:17:57 AMOct 21, 2021)
[error] Simulation completed with execution error on server: Local Machine. (10:18:03 AMOct 21, 2021)
October 22, 2021 at 3:44 pmblue_nun_7
SubscriberSOLVED!!
To solve this problem:
In Maxwell, click Simulation - HPC Options
Click Edit
Untick 'Use Automatic Setting'
In 'Tasks', change to 1 (for me it was 4 which gave the errors).
Click 'OK'.
Simulation should now work. Dont really understand why, but there we go!
Viewing 3 reply threads- The topic ‘Error with co-simulation between Maxwell and Simplorer – failure to send data between packages.’ is closed to new replies.
6625
1311
