February 20, 2019 at 10:00 am
adityak.eee17
SubscriberHello
I have been trying to obtain the thrust vs velocity characteristics of a linear motor, for which I created a parameter vel in the Motion Setup. The simulation runs for the initial value of vel = 0 m/s, but gives the following errors when optimetrics is set up to solve for velocities varying from 0 to 9 m/s, in steps of 1 m/s:
  [info] A variation (vel='1m_per_sec') has been requested using the following machines: Local Machine. (3:09:00 PM Feb 20, 2019)
  [info] User Defined Primitive: LinearMCore - One-turn length: 416.977 (mm). (3:09:01 PM Feb 20, 2019)
  [error] Separate operation failed due to lump count inconsistancy. Found 2 lumps instead of expected 19 lumps. (3:09:01 PM Feb 20, 2019)
  [error] Body could not be created for part Rph because of invalid parameters of this part or some of its parent part/coordinate system. (3:09:01 PM Feb 20, 2019)
 Find conduction path: 'R_1 (Rph_1_Section1)' is not on any conduction path(s). Please make sure that the it is applied to a conducting object. (3:09:03 PM Feb 20, 2019)
Null body found for part Rph. (3:09:03 PMÂ Feb 20, 2019)
Null body found for part Rph_Section1. (3:09:03 PMÂ Feb 20, 2019)
...Similar messages for all other vel values...
  [info] Parametric Analysis is done. (3:09
3 PMÂ Feb 20, 2019)
The strange thing is: when I go to the design properties and manually change the value of vel to, say, 1m/s, the simulation runs fine. The parameter variation is no longer automatic as I want it to be. I have to change vel manually.
If you have any suggestions to make the optimetrics analysis work, kindly help me out. Thank you.
April 2, 2019 at 1:48 pm
Mark Solveson
Ansys EmployeeHere are a few things to check:Â
Check the units of the variable as defined in the Parametric setup.Â
After the Solution Analyze, you can right click on ParametricSetup1 -> View Analysis Result, select a variation from the table, and click on Apply. This may help identify which the variations are called and diagnose where the issue is. Â
It may be that an excitation surface is not being moved with the geometry.Â
April 5, 2019 at 10:24 am
adityak.eee17
In my model, the band consists of a moving aluminium sheet and back iron only. The excitation surface (assuming it means the current/voltage sources) lies outside the band and does not move. Is it required to be inside the band?
I checked the parameter unit and it is fine (m/s).
August 20, 2019 at 11:54 am
balajisriram15
SubscriberHi Aditya, Balaji here from NIT, Can you share your Email ID or contact number to discuss regarding Maxwell?
my Ph No: +91 9884646838
- The topic ‘Error while solving Optimetrics’ is closed to new replies.
6575
1311
