LS Dyna
LS Dyna
Error when running on MPP but not on SMP mode
    • hweimeng
      I got an error -> "forrtl: severe (157): program exception - access violation" when running ls-dyna with S-ALE domain, in MPP run mode and using *ALE_Structured_Mesh_volume_filling keyword. Running the same file using SMP is ok. I have to used the keyword *Initial_volume_fraction_geometry to replace *ALE_Structured_Mesh_volume_filling in order to run MPP. I upgraded my solver to V252 but still have this problem. Wonder whether anyone encounters this issue as well.
    • erik.kostson
      Hi
      Please try and download the latest versions (2025 R2 is not the version) – latest LS-DYna versions are say R16.1. or R16.2. and see if it helps.
      Downlaod instruc.: Download LS-DYNA solver
      If the latest versions also give this error, contact your channel partner: CAD-IT-Consultants in your region and send them your model so they can try and help you.
      All the best
      Erko
    • hweimeng
      I believe 2025 R2 is R16 and it's still giving me error. I will check with CADIT. Thanks.
      Anyone with this issue please also feel free to mention here in case this is a genuine bug.
      • erik.kostson
        25R2 is shipped with
           |  Version : mpp d R14                              |
            |  Revision: R14.1.1-16-                 |
            |  AnLicVer: 2025 R2
        So downlaod as mentioned R16.1.0 or R16.1.1, or best the latest R16.2.0 and try that out first.
        If this does not help, send it to you channel partner – if they can reproduce it, then they will send it to us and we will look into further to see if this is an issue.
        Thank you
        Erko
