LS Dyna
LS Dyna
Download LS-DYNA solver
    • eceron
      Hi
      I would like to use a newer release version of the LS-DYNA solver. Where can i find/dowload it?
      thanks
      Ermanno
    • Nanda
      Hello User,
      You can download it from here: https://ftp.lstc.com/user/download_page.html
      The latest we have is 16.2
      Nanda
    • eceron
      Hello Nanda,
      thanks for the info. The page for downloade is password protected. Can I get access?
      ragards
      Ermanno
    • Nanda
      That would be:
      username: user
      password: computer
      All small, no CAPS!
[bingo_chatbox] ; jQuery(".user-experience-select").select2({ data: data, minimumResultsForSearch: -1, escapeMarkup: function(markup) { return markup; }, templateResult: function(data) { return data.html; }, templateSelection: function(data) { return data.text; } , dropdownParent: jQuery(".user-exp-outer") }); jQuery(".user-experience-select").select2("val", "https://innovationspace.ansys.com/ais-experiences/"); var timesClicked = 0; jQuery(".user-exp-outer").click(function(e) { timesClicked++; e.preventDefault(); if (timesClicked%2==0) { //run second function jQuery(".user-experience-select").select2("close"); } else { //run first function jQuery(".user-experience-select").select2("open"); jQuery(".user-exp-outer").addClass("active"); e.stopPropagation() } }) jQuery(document).on("click", function(a) { if (jQuery(a.target).is(".user-exp-outer") === false) { jQuery(".user-exp-outer").removeClass("active"); jQuery(".user-experience-select").select2("close"); timesClicked = 0; } }); jQuery(".user-experience-select").on("select2:select", function (e) { if(e.params.data.ais=="true"){ window.open(e.params.data.id,"_self"); } else{ window.open(e.params.data.id); } }); });
