September 20, 2020 at 10:54 pm
Amal85
SubscriberHi,
How to solve when this error happen? This error message came out when using HFSS module. The OS using is Linux. Is there any advise?
September 21, 2020 at 9:37 pmtsiriaks
Ansys EmployeeI would recommend to use HFSS/AEDT outside of the Workbench unless you really need Workbench for some unique functionalities.nSeptember 23, 2020 at 1:44 amAmal85
SubscriberStill need to use Workbench for the project and also has turned off security and firewall software but it does not work.nnSeptember 23, 2020 at 10:22 pmtsiriaks
Ansys EmployeeWhat version is this ?nIf you open up a blank Workbench session, then insert HFSS module and double click on Geometry cell, does it launch AEDT successfully ?nSeptember 30, 2020 at 2:59 amAmal85
SubscriberWhen double click on Geometry in workbench, AEDT cannot be launched. When launched AEDT alone, it come out with error : feature has expired. flexnet error -147, -10. However, the license is still valid. The version using now is 2019.R3nSeptember 30, 2020 at 7:38 pmtsiriaks
Ansys EmployeePlease post screenshot of the complete error message when launching stand-alone AEDTnAlso, open up Client ANSLIC_ADMIN Utility and check license status, then post the output of it herenOctober 9, 2020 at 1:50 amAmal85
SubscriberHi!n Thank you for your response. Finally we can open AEDT. This happen because of we used expired licenses key. After change to a new license key the software can be opened.nnViewing 6 reply threads- The topic ‘Error when opening HFSS’ is closed to new replies.
5799
