Electronics
Electronics
‘Error in mesh mapping on band error’ 3D induction motor simulation when
    • mqasim
      Hi, I'm simulating an induction motor in 3D. I have an outer rotor and inner stator, and the band is encompassing the rotor up to the middle of the airgap. When I set the mechanical speed in motion setup to a speed that is greater than zero, I get the following error:    'Error in mesh mapping on band error'   I was wondering how to fix this problem.   Another question, which is more accurate in torque calculations: Moving1.Torque or the user-assigned torque parameter on the band (Torque1.Torque)?   Thanks,  Mohamad
Viewing 0 reply threads
  • The topic ‘‘Error in mesh mapping on band error’ 3D induction motor simulation when’ is closed to new replies.
