August 17, 2021 at 4:24 am
Amir_AsadpoorDarvish
SubscriberI am constantly getting this Error whenever I am trying to run HFSS’s Analyze.
Error in HFSS: "Unable to create child process: hf3d. Please contact ANSYS technical support"
September 2, 2021 at 6:12 pmGeorge Karnos
Ansys EmployeeIf you are running locally
Try running without your firewall being enabled t test if the firewall is blocking mpi.
Also, are you running with vpn ?
September 5, 2021 at 10:58 pmAmir_AsadpoorDarvish
SubscriberHi Geo.
Thank you for your reply
I tried the firewall and made sure mpi is an allowed app, it didn't work.
.Yes, I am running with a VPN since my license is from my University and because of COVID I have to connect via VPN off-campus to activate my license.
Is there any way to fix it with the VPN connection?
Cheers Amir
Viewing 2 reply threads- The topic ‘Error in HFSS: “Unable to create child process: hf3d. Please contact ANSYS technical support”’ is closed to new replies.
5654
1890
1414
1303
