June 1, 2024 at 10:42 am
helin zou
SubscriberMeshingModelImportPartMgrExecLog
Label = 'ANSYS_MESH_FM_WARNING_ID_MESHINGMODEL_IMPORT_PARTMGR_ERROR'
DataTranslatorCommandExecLog
Label = 'ANSYS_MESH_FM_ERROR_ID_CONVERT_WORKBENCH_TO_FLTG_ERROR'
Error: Error in CAD Import
Error Object: #f
zone not found.
June 5, 2024 at 7:31 am
Yuanyuan Xiao
Ansys EmployeeHi Helin,
您好,请参考如下链接试试看:
/knowledge/forums/topic/error-when-reading-ansys-spaceclaim-geometry-file-scdoc-into-fluent-meshing-running-ansys-tgrid-cadtotgridconverter-failed/
Best regards,
Yuanyuan Xiao
- 主题 ‘Error in CAD Import’ 已关闭新回复.
- Application of EDC occurs flame extinguishing
- Must EDC model need an initial flow field?
- Difficulty in Complex Source Term Linearization
- Please help me check if there are any issues with the UDF.
- Negative droplet growth rate in Fluent wet steam model
- Compile the UDF code and apply it to the DPM.
- Energy Source Term formulation for multi-component condensation
- Please help me analyze the multiphase flow model for the phase change of liquid
1885
1403
1293
