April 3, 2024 at 4:33 pm
sahua1
SubscriberHello everyone,
I am trying to run a static structural simulation on a Linux-based SSH server and am receiving the error below. The server has ansys 2023R2 and my model is the 2022R2 version. I have tried running the same model on my computer, and it works fine. I have also checked the server, and it shows an error related to segmentation. I am unsure how to solve this error, and I kindly request you to support me. I have also attached possible reasons for this error from the forum.
Possible reason for the error showing on the forum:
Error showing on server:
April 11, 2024 at 3:14 pm
George Karnos
Ansys EmployeeAre there any errors in the file.out file for the simulation.
This file should be in the working directory.
Are you running locally on the linux server or are you using RSM to solve remotely to the linux server from your machine? -
April 16, 2024 at 4:42 pm
sahua1
SubscriberHi George,
Thank you for the response.
We are running locally on the Linux server.
Please find below the log details. (I am not able to attach the file so I am pasting the log here)
Event log opened 4/16/2024 12:18:20 PM ESTÂProduct version: 2023 R2Build version: 23.2.0.0Â{4/16/2024 12:18:36 PM} [ProjectReplaced:Project] A new project has been created.Â{4/16/2024 12:18:55 PM} [ProjectReplaced:Project] The project has been opened from /home/pateh123/Harsh simulation/Server analysis/server_run.wbpj.Â{4/16/2024 12:19:37 PM} [BatchModeApplicationWarning:MechanicalEditor] For Frictionless Supports applied to neighboring faces that meet at a shared edge, if the angle formed between the normals of the neighboring faces is larger than 0.01 degree, the nodes on the shared edge are subject to two separate combinations of DOF constraints, one from each Frictionless Support. The Mechanical application attempts to identify a suitable orientation to the nodal coordinate system that accommodates both frictionless supports and, if successful, constrain its axes accordingly.Â{4/16/2024 12:19:37 PM} [BatchModeApplicationError:MechanicalEditor] An error occurred while starting the solver module. Please refer to the Troubleshooting section in the Ansys Mechanical User Guide for more information.Â{4/16/2024 12:19:40 PM} [UpdateMessage:Project] Update of the Solution component in Seperate key with press fit_new_maetrial failed: Error updating cell Solution in system Seperate key with press fit_new_maetrial.Ansys.Core.Commands.UserReadableFailureException: Error updating cell Solution in system Seperate key with press fit_new_maetrial. at Ansys.Addins.Infrastructure.CommandUtilities.CommandHelper.Execute (Ansys.Core.Commands.IFullContext context) [0x0004b] in:0  at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, Ansys.Core.Commands.Concurrency.IExecutionEngineCallback tracer) [0x000a1] in:0  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, Ansys.Core.Commands.CommandContext subContext) [0x0002d] in:0  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, System.Boolean dontCatchExceptions) [0x0010f] in:0 --- Ansys.Core.Commands.CommandFailedException: Error updating cell Solution in system Seperate key with press fit_new_maetrial.CommandName: Mechanical.UpdateSolution(Container="Solution", RemainingDownstreamContainers=["Results"], UpdateOptions=Set(DpUpdateType=None, HeldLicenseId=None, LicenseStatsId="5456da2eb0ae4a05a4891d7a134bb697", DesignPointUpdateQueue=None, MaxNumberOfCores=0)) at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x0000c] in:0  at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x000dd] in:0  at Ansys.ProjectSchematic.Data.ComponentTemplateEntity.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.Core.DataModel.ProjectSystem.DataContainerReference container, System.String dataGroup, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x000cb] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.UpdateTask.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x0003d] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin.updateComponent (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.Update.UpdateTask task, System.String trackToken, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.TaskHolder remainingTasksInThisDp, System.Collections.Generic.List1[T] dependentTasks) [0x00130] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin+<>c__DisplayClass0_0.b__0 () [0x00000] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.ExecuteWithErrorBehaviour.Execute (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.UpdateErrorBehavior behavior, System.Action op, Ansys.ProjectSchematic.Update.UpdateTask forTask, System.Action opUponError) [0x0007e] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0{4/16/2024 12:19:41 PM} [Ansys.Core.Commands.CommandFailedException:Message] Update failed for the Solution component in Seperate key with press fit_new_maetrial. Error updating cell Solution in system Seperate key with press fit_new_maetrial.Ansys.Core.Commands.UserReadableFailureException: Error updating cell Solution in system Seperate key with press fit_new_maetrial.at Ansys.Addins.Infrastructure.CommandUtilities.CommandHelper.Execute (Ansys.Core.Commands.IFullContext context) [0x0004b] in:0 at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, Ansys.Core.Commands.Concurrency.IExecutionEngineCallback tracer) [0x000a1] in:0 at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, Ansys.Core.Commands.CommandContext subContext) [0x0002d] in:0 at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, System.Boolean dontCatchExceptions) [0x0010f] in:0 --- Ansys.Core.Commands.CommandFailedException: Error updating cell Solution in system Seperate key with press fit_new_maetrial.CommandName: Mechanical.UpdateSolution(Container="Solution", RemainingDownstreamContainers=["Results"], UpdateOptions=Set(DpUpdateType=None, HeldLicenseId=None, LicenseStatsId="5456da2eb0ae4a05a4891d7a134bb697", DesignPointUpdateQueue=None, MaxNumberOfCores=0))at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x0000c] in:0 at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x000dd] in:0 at Ansys.ProjectSchematic.Data.ComponentTemplateEntity.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.Core.DataModel.ProjectSystem.DataContainerReference container, System.String dataGroup, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x000cb] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0at Ansys.ProjectSchematic.Update.UpdateTask.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x0003d] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin.updateComponent (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.Update.UpdateTask task, System.String trackToken, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.TaskHolder remainingTasksInThisDp, System.Collections.Generic.List1[T] dependentTasks) [0x00130] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin+<>c__DisplayClass0_0.b__0 () [0x00000] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0  at Ansys.ProjectSchematic.Update.ExecuteWithErrorBehaviour.Execute (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.UpdateErrorBehavior behavior, System.Action op, Ansys.ProjectSchematic.Update.UpdateTask forTask, System.Action opUponError) [0x0007e] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0Â--- Ansys.Core.Commands.UserReadableFailureException: Update failed for the Solution component in Seperate key with press fit_new_maetrial. Error updating cell Solution in system Seperate key with press fit_new_maetrial. at Ansys.ProjectSchematic.Update.UpdateImpl.throwErrorIfSomethingFailed () [0x0011f] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.UpdateImpl+d__73.MoveNext () [0x00bc1] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0  at Ansys.ProjectSchematic.Update.UpdateCommandProcess+d__5.MoveNext () [0x00071] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0  at Ansys.Core.Commands.Concurrency.SuspendableCommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, Ansys.Core.Commands.Concurrency.IExecutionEngineCallback tracer) [0x00142] in:0  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, Ansys.Core.Commands.CommandContext subContext) [0x0002d] in:0  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, System.Boolean dontCatchExceptions) [0x0010f] in:0 --- Ansys.Core.Commands.CommandFailedException: Update failed for the Solution component in Seperate key with press fit_new_maetrial. Error updating cell Solution in system Seperate key with press fit_new_maetrial.CommandName: UpdateSystem(System="/Schematic/System:SYS", AllDependencies=True) at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x0000c] in:0  at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x000dd] in:0  at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (Ansys.Core.Commands.CommandAsyncResult+ISuspendResumeCommands suspendResumeHandler, System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x00007] in:0  at Ansys.ProjectSchematic.GuiOperations.AbstractUpdateSystemGui.Invoke (Ansys.UI.Abstract.IUserInteractor context) [0x000dd] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.UI.Abstract.ProductionUserInvokedOperation1[T].Invoke (Ansys.UI.GuiOperationContext context) [0x0000c] in:0 at Ansys.UI.GuiOperationContext.Invoke (Ansys.UI.GuiOperationMetaData operationData) [0x00006] in:0 at Ansys.UI.UIManager+<>c__DisplayClass206_0.b__0 () [0x00031] in :0 at Ansys.UI.UIManager.InvokeOperationCore (System.String pseudoname, Ansys.UI.Views.View+OperationDelegate callback, System.Boolean allowOSMessages, System.Boolean coreTransaction, System.Boolean deferredRefreshOnly) [0x001a6] in:0 {4/16/2024 12:22:21 PM} [BatchModeApplicationWarning:MechanicalEditor] For Frictionless Supports applied to neighboring faces that meet at a shared edge, if the angle formed between the normals of the neighboring faces is larger than 0.01 degree, the nodes on the shared edge are subject to two separate combinations of DOF constraints, one from each Frictionless Support. The Mechanical application attempts to identify a suitable orientation to the nodal coordinate system that accommodates both frictionless supports and, if successful, constrain its axes accordingly.{4/16/2024 12:22:21 PM} [BatchModeApplicationWarning:MechanicalEditor] Not enough constraints appear to be applied to prevent rigid body motion. This may lead to solution warnings or errors. Check results carefully.{4/16/2024 12:22:21 PM} [BatchModeApplicationError:MechanicalEditor] An error occurred while starting the solver module. Please refer to the Troubleshooting section in the Ansys Mechanical User Guide for more information.{4/16/2024 12:22:29 PM} [UpdateMessage:Project] Update of the Solution component in Full stack failed: Error updating cell Solution in system Full stack.Ansys.Core.Commands.UserReadableFailureException: Error updating cell Solution in system Full stack.at Ansys.Addins.Infrastructure.CommandUtilities.CommandHelper.Execute (Ansys.Core.Commands.IFullContext context) [0x0004b] in:0 at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, Ansys.Core.Commands.Concurrency.IExecutionEngineCallback tracer) [0x000a1] in:0 at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, Ansys.Core.Commands.CommandContext subContext) [0x0002d] in:0 at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, System.Boolean dontCatchExceptions) [0x0010f] in:0 --- Ansys.Core.Commands.CommandFailedException: Error updating cell Solution in system Full stack.CommandName: Mechanical.UpdateSolution(Container="Solution 2", RemainingDownstreamContainers=["Results 2"], UpdateOptions=Set(DpUpdateType=None, HeldLicenseId=None, LicenseStatsId="eeccc522205f4dca87e2b4f21c9f9dde", DesignPointUpdateQueue=None, MaxNumberOfCores=0))at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x0000c] in:0 at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x000dd] in:0 at Ansys.ProjectSchematic.Data.ComponentTemplateEntity.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.Core.DataModel.ProjectSystem.DataContainerReference container, System.String dataGroup, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x000cb] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0at Ansys.ProjectSchematic.Update.UpdateTask.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x0003d] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin.updateComponent (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.Update.UpdateTask task, System.String trackToken, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.TaskHolder remainingTasksInThisDp, System.Collections.Generic.List1[T] dependentTasks) [0x00130] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin+<>c__DisplayClass0_0.b__0 () [0x00000] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0  at Ansys.ProjectSchematic.Update.ExecuteWithErrorBehaviour.Execute (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.UpdateErrorBehavior behavior, System.Action op, Ansys.ProjectSchematic.Update.UpdateTask forTask, System.Action opUponError) [0x0007e] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0Â{4/16/2024 12:22:29 PM} [Ansys.Core.Commands.CommandFailedException:Message] Update failed for the Solution component in Full stack. Error updating cell Solution in system Full stack.Ansys.Core.Commands.UserReadableFailureException: Error updating cell Solution in system Full stack. at Ansys.Addins.Infrastructure.CommandUtilities.CommandHelper.Execute (Ansys.Core.Commands.IFullContext context) [0x0004b] in:0  at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, Ansys.Core.Commands.Concurrency.IExecutionEngineCallback tracer) [0x000a1] in:0  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, Ansys.Core.Commands.CommandContext subContext) [0x0002d] in:0  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, System.Boolean dontCatchExceptions) [0x0010f] in:0 --- Ansys.Core.Commands.CommandFailedException: Error updating cell Solution in system Full stack.CommandName: Mechanical.UpdateSolution(Container="Solution 2", RemainingDownstreamContainers=["Results 2"], UpdateOptions=Set(DpUpdateType=None, HeldLicenseId=None, LicenseStatsId="eeccc522205f4dca87e2b4f21c9f9dde", DesignPointUpdateQueue=None, MaxNumberOfCores=0)) at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x0000c] in:0  at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x000dd] in:0  at Ansys.ProjectSchematic.Data.ComponentTemplateEntity.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.Core.DataModel.ProjectSystem.DataContainerReference container, System.String dataGroup, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x000cb] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.UpdateTask.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x0003d] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin.updateComponent (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.Update.UpdateTask task, System.String trackToken, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.TaskHolder remainingTasksInThisDp, System.Collections.Generic.List1[T] dependentTasks) [0x00130] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin+<>c__DisplayClass0_0.b__0 () [0x00000] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.ExecuteWithErrorBehaviour.Execute (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.UpdateErrorBehavior behavior, System.Action op, Ansys.ProjectSchematic.Update.UpdateTask forTask, System.Action opUponError) [0x0007e] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0--- Ansys.Core.Commands.UserReadableFailureException: Update failed for the Solution component in Full stack. Error updating cell Solution in system Full stack.at Ansys.ProjectSchematic.Update.UpdateImpl.throwErrorIfSomethingFailed () [0x0011f] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0at Ansys.ProjectSchematic.Update.UpdateImpl+d__73.MoveNext () [0x00bc1] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.UpdateCommandProcess+d__5.MoveNext () [0x00071] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.Core.Commands.Concurrency.SuspendableCommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, Ansys.Core.Commands.Concurrency.IExecutionEngineCallback tracer) [0x00142] in:0 at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, Ansys.Core.Commands.CommandContext subContext) [0x0002d] in:0 at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, System.Boolean dontCatchExceptions) [0x0010f] in:0 --- Ansys.Core.Commands.CommandFailedException: Update failed for the Solution component in Full stack. Error updating cell Solution in system Full stack.CommandName: UpdateSystem(System="/Schematic/System:SYS 2", AllDependencies=True)at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x0000c] in:0 at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x000dd] in:0 at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (Ansys.Core.Commands.CommandAsyncResult+ISuspendResumeCommands suspendResumeHandler, System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x00007] in:0 at Ansys.ProjectSchematic.GuiOperations.AbstractUpdateSystemGui.Invoke (Ansys.UI.Abstract.IUserInteractor context) [0x000dd] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0at Ansys.UI.Abstract.ProductionUserInvokedOperation1[T].Invoke (Ansys.UI.GuiOperationContext context) [0x0000c] in:0  at Ansys.UI.GuiOperationContext.Invoke (Ansys.UI.GuiOperationMetaData operationData) [0x00006] in:0  at Ansys.UI.UIManager+<>c__DisplayClass206_0.b__0 () [0x00031] in :0  at Ansys.UI.UIManager.InvokeOperationCore (System.String pseudoname, Ansys.UI.Views.View+OperationDelegate callback, System.Boolean allowOSMessages, System.Boolean coreTransaction, System.Boolean deferredRefreshOnly) [0x001a6] in:0 Â{4/16/2024 12:22:52 PM} [ProjectSaved:Project] The current project has been saved: /home/pateh123/Harsh simulation/Server analysis/server_run.wbpj. -
April 16, 2024 at 6:36 pm
George Karnos
Ansys EmployeeOne item I see is that the directory where the project is stored has spaces in the name.
Can you try removing the spaces?
The project has been opened from /home/pateh123/Harsh simulation/Server analysis/server_run.wbpj.Â/home/pateh123/Harsh_simulation/Server_analysis/server_run.wbpj. -
April 16, 2024 at 7:05 pm
sahua1
SubscriberThank you for the response. I have renamed the folders. But, it is still showing the same error. Log of same is as below.
Event log opened 4/16/2024 2:59:24 PM ESTÂProduct version: 2023 R2Build version: 23.2.0.0Â{4/16/2024 2:59:41 PM} [ProjectReplaced:Project] A new project has been created.Â{4/16/2024 3:00:09 PM} [ProjectReplaced:Project] The project has been opened from /home/pateh123/harsh_simulation/server_analysis/server_run.wbpj.Â{4/16/2024 3:00:45 PM} [BatchModeApplicationWarning:MechanicalEditor] For Frictionless Supports applied to neighboring faces that meet at a shared edge, if the angle formed between the normals of the neighboring faces is larger than 0.01 degree, the nodes on the shared edge are subject to two separate combinations of DOF constraints, one from each Frictionless Support. The Mechanical application attempts to identify a suitable orientation to the nodal coordinate system that accommodates both frictionless supports and, if successful, constrain its axes accordingly.Â{4/16/2024 3:00:45 PM} [BatchModeApplicationError:MechanicalEditor] An error occurred while starting the solver module. Please refer to the Troubleshooting section in the Ansys Mechanical User Guide for more information.Â{4/16/2024 3:00:48 PM} [UpdateMessage:Project] Update of the Solution component in Seperate key with press fit_new_maetrial failed: Error updating cell Solution in system Seperate key with press fit_new_maetrial.Ansys.Core.Commands.UserReadableFailureException: Error updating cell Solution in system Seperate key with press fit_new_maetrial. at Ansys.Addins.Infrastructure.CommandUtilities.CommandHelper.Execute (Ansys.Core.Commands.IFullContext context) [0x0004b] in:0  at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, Ansys.Core.Commands.Concurrency.IExecutionEngineCallback tracer) [0x000a1] in:0  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, Ansys.Core.Commands.CommandContext subContext) [0x0002d] in:0  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, System.Boolean dontCatchExceptions) [0x0010f] in:0 --- Ansys.Core.Commands.CommandFailedException: Error updating cell Solution in system Seperate key with press fit_new_maetrial.CommandName: Mechanical.UpdateSolution(Container="Solution", RemainingDownstreamContainers=["Results"], UpdateOptions=Set(DpUpdateType=None, HeldLicenseId=None, LicenseStatsId="ead2577022e64eca9365aff88d40bbf7", DesignPointUpdateQueue=None, MaxNumberOfCores=0)) at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x0000c] in:0  at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x000dd] in:0  at Ansys.ProjectSchematic.Data.ComponentTemplateEntity.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.Core.DataModel.ProjectSystem.DataContainerReference container, System.String dataGroup, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x000cb] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.UpdateTask.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x0003d] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin.updateComponent (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.Update.UpdateTask task, System.String trackToken, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.TaskHolder remainingTasksInThisDp, System.Collections.Generic.List1[T] dependentTasks) [0x00130] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin+<>c__DisplayClass0_0.b__0 () [0x00000] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.ExecuteWithErrorBehaviour.Execute (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.UpdateErrorBehavior behavior, System.Action op, Ansys.ProjectSchematic.Update.UpdateTask forTask, System.Action opUponError) [0x0007e] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0{4/16/2024 3:00:49 PM} [Ansys.Core.Commands.CommandFailedException:Message] Update failed for the Solution component in Seperate key with press fit_new_maetrial. Error updating cell Solution in system Seperate key with press fit_new_maetrial.Ansys.Core.Commands.UserReadableFailureException: Error updating cell Solution in system Seperate key with press fit_new_maetrial.at Ansys.Addins.Infrastructure.CommandUtilities.CommandHelper.Execute (Ansys.Core.Commands.IFullContext context) [0x0004b] in:0 at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, Ansys.Core.Commands.Concurrency.IExecutionEngineCallback tracer) [0x000a1] in:0 at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, Ansys.Core.Commands.CommandContext subContext) [0x0002d] in:0 at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, System.Boolean dontCatchExceptions) [0x0010f] in:0 --- Ansys.Core.Commands.CommandFailedException: Error updating cell Solution in system Seperate key with press fit_new_maetrial.CommandName: Mechanical.UpdateSolution(Container="Solution", RemainingDownstreamContainers=["Results"], UpdateOptions=Set(DpUpdateType=None, HeldLicenseId=None, LicenseStatsId="ead2577022e64eca9365aff88d40bbf7", DesignPointUpdateQueue=None, MaxNumberOfCores=0))at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x0000c] in:0 at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x000dd] in:0 at Ansys.ProjectSchematic.Data.ComponentTemplateEntity.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.Core.DataModel.ProjectSystem.DataContainerReference container, System.String dataGroup, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x000cb] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0at Ansys.ProjectSchematic.Update.UpdateTask.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x0003d] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin.updateComponent (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.Update.UpdateTask task, System.String trackToken, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.TaskHolder remainingTasksInThisDp, System.Collections.Generic.List1[T] dependentTasks) [0x00130] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin+<>c__DisplayClass0_0.b__0 () [0x00000] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0  at Ansys.ProjectSchematic.Update.ExecuteWithErrorBehaviour.Execute (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.UpdateErrorBehavior behavior, System.Action op, Ansys.ProjectSchematic.Update.UpdateTask forTask, System.Action opUponError) [0x0007e] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0Â--- Ansys.Core.Commands.UserReadableFailureException: Update failed for the Solution component in Seperate key with press fit_new_maetrial. Error updating cell Solution in system Seperate key with press fit_new_maetrial. at Ansys.ProjectSchematic.Update.UpdateImpl.throwErrorIfSomethingFailed () [0x0011f] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.UpdateImpl+d__73.MoveNext () [0x00bc1] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0  at Ansys.ProjectSchematic.Update.UpdateCommandProcess+d__5.MoveNext () [0x00071] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0  at Ansys.Core.Commands.Concurrency.SuspendableCommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, Ansys.Core.Commands.Concurrency.IExecutionEngineCallback tracer) [0x00142] in:0  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, Ansys.Core.Commands.CommandContext subContext) [0x0002d] in:0  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, System.Boolean dontCatchExceptions) [0x0010f] in:0 --- Ansys.Core.Commands.CommandFailedException: Update failed for the Solution component in Seperate key with press fit_new_maetrial. Error updating cell Solution in system Seperate key with press fit_new_maetrial.CommandName: UpdateSystem(System="/Schematic/System:SYS", AllDependencies=True) at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x0000c] in:0  at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x000dd] in:0  at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (Ansys.Core.Commands.CommandAsyncResult+ISuspendResumeCommands suspendResumeHandler, System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x00007] in:0  at Ansys.ProjectSchematic.GuiOperations.AbstractUpdateSystemGui.Invoke (Ansys.UI.Abstract.IUserInteractor context) [0x000dd] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.UI.Abstract.ProductionUserInvokedOperation1[T].Invoke (Ansys.UI.GuiOperationContext context) [0x0000c] in:0 at Ansys.UI.GuiOperationContext.Invoke (Ansys.UI.GuiOperationMetaData operationData) [0x00006] in:0 at Ansys.UI.UIManager+<>c__DisplayClass206_0.b__0 () [0x00031] in :0 at Ansys.UI.UIManager.InvokeOperationCore (System.String pseudoname, Ansys.UI.Views.View+OperationDelegate callback, System.Boolean allowOSMessages, System.Boolean coreTransaction, System.Boolean deferredRefreshOnly) [0x001a6] in:0 {4/16/2024 3:01:54 PM} [BatchModeApplicationWarning:MechanicalEditor] For Frictionless Supports applied to neighboring faces that meet at a shared edge, if the angle formed between the normals of the neighboring faces is larger than 0.01 degree, the nodes on the shared edge are subject to two separate combinations of DOF constraints, one from each Frictionless Support. The Mechanical application attempts to identify a suitable orientation to the nodal coordinate system that accommodates both frictionless supports and, if successful, constrain its axes accordingly.{4/16/2024 3:01:54 PM} [BatchModeApplicationError:MechanicalEditor] An error occurred while starting the solver module. Please refer to the Troubleshooting section in the Ansys Mechanical User Guide for more information.{4/16/2024 3:01:57 PM} [UpdateMessage:Project] Update of the Solution component in seperate_key_with_press fit_new_maetrial failed: Error updating cell Solution in system seperate_key_with_press fit_new_maetrial.Ansys.Core.Commands.UserReadableFailureException: Error updating cell Solution in system seperate_key_with_press fit_new_maetrial.at Ansys.Addins.Infrastructure.CommandUtilities.CommandHelper.Execute (Ansys.Core.Commands.IFullContext context) [0x0004b] in:0 at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, Ansys.Core.Commands.Concurrency.IExecutionEngineCallback tracer) [0x000a1] in:0 at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, Ansys.Core.Commands.CommandContext subContext) [0x0002d] in:0 at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, System.Boolean dontCatchExceptions) [0x0010f] in:0 --- Ansys.Core.Commands.CommandFailedException: Error updating cell Solution in system seperate_key_with_press fit_new_maetrial.CommandName: Mechanical.UpdateSolution(Container="Solution", RemainingDownstreamContainers=["Results"], UpdateOptions=Set(DpUpdateType=None, HeldLicenseId=None, LicenseStatsId="ee9b589218fa44609599c4bb3272d9c5", DesignPointUpdateQueue=None, MaxNumberOfCores=0))at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x0000c] in:0 at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x000dd] in:0 at Ansys.ProjectSchematic.Data.ComponentTemplateEntity.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.Core.DataModel.ProjectSystem.DataContainerReference container, System.String dataGroup, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x000cb] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0at Ansys.ProjectSchematic.Update.UpdateTask.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x0003d] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin.updateComponent (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.Update.UpdateTask task, System.String trackToken, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.TaskHolder remainingTasksInThisDp, System.Collections.Generic.List1[T] dependentTasks) [0x00130] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin+<>c__DisplayClass0_0.b__0 () [0x00000] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0  at Ansys.ProjectSchematic.Update.ExecuteWithErrorBehaviour.Execute (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.UpdateErrorBehavior behavior, System.Action op, Ansys.ProjectSchematic.Update.UpdateTask forTask, System.Action opUponError) [0x0007e] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0Â{4/16/2024 3:01:58 PM} [Ansys.Core.Commands.CommandFailedException:Message] Update failed for the Solution component in seperate_key_with_press fit_new_maetrial. Error updating cell Solution in system seperate_key_with_press fit_new_maetrial.Ansys.Core.Commands.UserReadableFailureException: Error updating cell Solution in system seperate_key_with_press fit_new_maetrial. at Ansys.Addins.Infrastructure.CommandUtilities.CommandHelper.Execute (Ansys.Core.Commands.IFullContext context) [0x0004b] in:0  at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, Ansys.Core.Commands.Concurrency.IExecutionEngineCallback tracer) [0x000a1] in:0  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, Ansys.Core.Commands.CommandContext subContext) [0x0002d] in:0  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, System.Boolean dontCatchExceptions) [0x0010f] in:0 --- Ansys.Core.Commands.CommandFailedException: Error updating cell Solution in system seperate_key_with_press fit_new_maetrial.CommandName: Mechanical.UpdateSolution(Container="Solution", RemainingDownstreamContainers=["Results"], UpdateOptions=Set(DpUpdateType=None, HeldLicenseId=None, LicenseStatsId="ee9b589218fa44609599c4bb3272d9c5", DesignPointUpdateQueue=None, MaxNumberOfCores=0)) at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x0000c] in:0  at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x000dd] in:0  at Ansys.ProjectSchematic.Data.ComponentTemplateEntity.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.Core.DataModel.ProjectSystem.DataContainerReference container, System.String dataGroup, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x000cb] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.UpdateTask.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x0003d] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin.updateComponent (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.Update.UpdateTask task, System.String trackToken, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.TaskHolder remainingTasksInThisDp, System.Collections.Generic.List1[T] dependentTasks) [0x00130] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin+<>c__DisplayClass0_0.b__0 () [0x00000] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.ExecuteWithErrorBehaviour.Execute (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.UpdateErrorBehavior behavior, System.Action op, Ansys.ProjectSchematic.Update.UpdateTask forTask, System.Action opUponError) [0x0007e] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0--- Ansys.Core.Commands.UserReadableFailureException: Update failed for the Solution component in seperate_key_with_press fit_new_maetrial. Error updating cell Solution in system seperate_key_with_press fit_new_maetrial.at Ansys.ProjectSchematic.Update.UpdateImpl.throwErrorIfSomethingFailed () [0x0011f] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0at Ansys.ProjectSchematic.Update.UpdateImpl+d__73.MoveNext () [0x00bc1] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.UpdateCommandProcess+d__5.MoveNext () [0x00071] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.Core.Commands.Concurrency.SuspendableCommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, Ansys.Core.Commands.Concurrency.IExecutionEngineCallback tracer) [0x00142] in:0 at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, Ansys.Core.Commands.CommandContext subContext) [0x0002d] in:0 at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, System.Boolean dontCatchExceptions) [0x0010f] in:0 --- Ansys.Core.Commands.CommandFailedException: Update failed for the Solution component in seperate_key_with_press fit_new_maetrial. Error updating cell Solution in system seperate_key_with_press fit_new_maetrial.CommandName: UpdateSystem(System="/Schematic/System:SYS", AllDependencies=True)at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x0000c] in:0 at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x000dd] in:0 at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (Ansys.Core.Commands.CommandAsyncResult+ISuspendResumeCommands suspendResumeHandler, System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x00007] in:0 at Ansys.ProjectSchematic.GuiOperations.AbstractUpdateSystemGui.Invoke (Ansys.UI.Abstract.IUserInteractor context) [0x000dd] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0at Ansys.UI.Abstract.ProductionUserInvokedOperation1[T].Invoke (Ansys.UI.GuiOperationContext context) [0x0000c] in:0  at Ansys.UI.GuiOperationContext.Invoke (Ansys.UI.GuiOperationMetaData operationData) [0x00006] in:0  at Ansys.UI.UIManager+<>c__DisplayClass206_0.b__0 () [0x00031] in :0  at Ansys.UI.UIManager.InvokeOperationCore (System.String pseudoname, Ansys.UI.Views.View+OperationDelegate callback, System.Boolean allowOSMessages, System.Boolean coreTransaction, System.Boolean deferredRefreshOnly) [0x001a6] in:0 Â{4/16/2024 3:03:19 PM} [BatchModeApplicationWarning:MechanicalEditor] For Frictionless Supports applied to neighboring faces that meet at a shared edge, if the angle formed between the normals of the neighboring faces is larger than 0.01 degree, the nodes on the shared edge are subject to two separate combinations of DOF constraints, one from each Frictionless Support. The Mechanical application attempts to identify a suitable orientation to the nodal coordinate system that accommodates both frictionless supports and, if successful, constrain its axes accordingly.Â{4/16/2024 3:03:19 PM} [BatchModeApplicationWarning:MechanicalEditor] Not enough constraints appear to be applied to prevent rigid body motion. This may lead to solution warnings or errors. Check results carefully.Â{4/16/2024 3:03:19 PM} [BatchModeApplicationError:MechanicalEditor] An error occurred while starting the solver module. Please refer to the Troubleshooting section in the Ansys Mechanical User Guide for more information.Â{4/16/2024 3:03:26 PM} [UpdateMessage:Project] Update of the Solution component in full_stack failed: Error updating cell Solution in system full_stack.Ansys.Core.Commands.UserReadableFailureException: Error updating cell Solution in system full_stack. at Ansys.Addins.Infrastructure.CommandUtilities.CommandHelper.Execute (Ansys.Core.Commands.IFullContext context) [0x0004b] in:0  at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, Ansys.Core.Commands.Concurrency.IExecutionEngineCallback tracer) [0x000a1] in:0  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, Ansys.Core.Commands.CommandContext subContext) [0x0002d] in:0  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, System.Boolean dontCatchExceptions) [0x0010f] in:0 --- Ansys.Core.Commands.CommandFailedException: Error updating cell Solution in system full_stack.CommandName: Mechanical.UpdateSolution(Container="Solution 2", RemainingDownstreamContainers=["Results 2"], UpdateOptions=Set(DpUpdateType=None, HeldLicenseId=None, LicenseStatsId="05ed813b0786476584303aa31a3679e6", DesignPointUpdateQueue=None, MaxNumberOfCores=0)) at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x0000c] in:0  at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x000dd] in:0  at Ansys.ProjectSchematic.Data.ComponentTemplateEntity.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.Core.DataModel.ProjectSystem.DataContainerReference container, System.String dataGroup, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x000cb] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.UpdateTask.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x0003d] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin.updateComponent (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.Update.UpdateTask task, System.String trackToken, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.TaskHolder remainingTasksInThisDp, System.Collections.Generic.List1[T] dependentTasks) [0x00130] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin+<>c__DisplayClass0_0.b__0 () [0x00000] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.ExecuteWithErrorBehaviour.Execute (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.UpdateErrorBehavior behavior, System.Action op, Ansys.ProjectSchematic.Update.UpdateTask forTask, System.Action opUponError) [0x0007e] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0{4/16/2024 3:03:28 PM} [Ansys.Core.Commands.CommandFailedException:Message] Update failed for the Solution component in full_stack. Error updating cell Solution in system full_stack.Ansys.Core.Commands.UserReadableFailureException: Error updating cell Solution in system full_stack.at Ansys.Addins.Infrastructure.CommandUtilities.CommandHelper.Execute (Ansys.Core.Commands.IFullContext context) [0x0004b] in:0 at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, Ansys.Core.Commands.Concurrency.IExecutionEngineCallback tracer) [0x000a1] in:0 at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, Ansys.Core.Commands.CommandContext subContext) [0x0002d] in:0 at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, System.Boolean dontCatchExceptions) [0x0010f] in:0 --- Ansys.Core.Commands.CommandFailedException: Error updating cell Solution in system full_stack.CommandName: Mechanical.UpdateSolution(Container="Solution 2", RemainingDownstreamContainers=["Results 2"], UpdateOptions=Set(DpUpdateType=None, HeldLicenseId=None, LicenseStatsId="05ed813b0786476584303aa31a3679e6", DesignPointUpdateQueue=None, MaxNumberOfCores=0))at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x0000c] in:0 at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x000dd] in:0 at Ansys.ProjectSchematic.Data.ComponentTemplateEntity.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.Core.DataModel.ProjectSystem.DataContainerReference container, System.String dataGroup, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x000cb] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0at Ansys.ProjectSchematic.Update.UpdateTask.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x0003d] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin.updateComponent (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.Update.UpdateTask task, System.String trackToken, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.TaskHolder remainingTasksInThisDp, System.Collections.Generic.List1[T] dependentTasks) [0x00130] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin+<>c__DisplayClass0_0.b__0 () [0x00000] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0  at Ansys.ProjectSchematic.Update.ExecuteWithErrorBehaviour.Execute (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.UpdateErrorBehavior behavior, System.Action op, Ansys.ProjectSchematic.Update.UpdateTask forTask, System.Action opUponError) [0x0007e] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0Â--- Ansys.Core.Commands.UserReadableFailureException: Update failed for the Solution component in full_stack. Error updating cell Solution in system full_stack. at Ansys.ProjectSchematic.Update.UpdateImpl.throwErrorIfSomethingFailed () [0x0011f] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.UpdateImpl+d__73.MoveNext () [0x00bc1] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0  at Ansys.ProjectSchematic.Update.UpdateCommandProcess+d__5.MoveNext () [0x00071] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0  at Ansys.Core.Commands.Concurrency.SuspendableCommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, Ansys.Core.Commands.Concurrency.IExecutionEngineCallback tracer) [0x00142] in:0  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, Ansys.Core.Commands.CommandContext subContext) [0x0002d] in:0  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, System.Boolean dontCatchExceptions) [0x0010f] in:0 --- Ansys.Core.Commands.CommandFailedException: Update failed for the Solution component in full_stack. Error updating cell Solution in system full_stack.CommandName: UpdateSystem(System="/Schematic/System:SYS 2", AllDependencies=True) at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x0000c] in:0  at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x000dd] in:0  at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (Ansys.Core.Commands.CommandAsyncResult+ISuspendResumeCommands suspendResumeHandler, System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x00007] in:0  at Ansys.ProjectSchematic.GuiOperations.AbstractUpdateSystemGui.Invoke (Ansys.UI.Abstract.IUserInteractor context) [0x000dd] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.UI.Abstract.ProductionUserInvokedOperation`1[T].Invoke (Ansys.UI.GuiOperationContext context) [0x0000c] in:0  at Ansys.UI.GuiOperationContext.Invoke (Ansys.UI.GuiOperationMetaData operationData) [0x00006] in:0  at Ansys.UI.UIManager+<>c__DisplayClass206_0.b__0 () [0x00031] in :0  at Ansys.UI.UIManager.InvokeOperationCore (System.String pseudoname, Ansys.UI.Views.View+OperationDelegate callback, System.Boolean allowOSMessages, System.Boolean coreTransaction, System.Boolean deferredRefreshOnly) [0x001a6] in:0  -
April 16, 2024 at 7:38 pm
George Karnos
Ansys EmployeeÂ
What is the Operating system?
SuSE, Redhat, Ubuntu
What version of the OS?
What is in the Solver out file?
check the solver output on the solution information tab.Does this happen with all project files?
April 17, 2024 at 3:20 pm
- The topic ‘Error in Ansys linux based server simulation’ is closed to new replies.
4597
1495
1386
1209
