July 11, 2024 at 7:20 pm
Ranga Swamy Balimidi
SubscriberHi,
We are trying to run Ansys fluent on our Linux HPC environment but facing issue connecting to the license server. The license server is reachable through telnet from the client machine .
We’ve set licensing file environment variable as per Ansys documentation from below link.
export ANSYSLMD_LICENSE_FILE=
referred page: https://optics.ansys.com/hc/en-us/articles/7595785040403-Setting-environment-variable-in-Linux
We are running Fluent as below per the Ansys docs.
$ ./fluent -g 2d
/cm/shared/apps/ansys/v241/fluent/fluent24.1.0/bin/fluent -r24.1.0 -g 2d
/cm/shared/apps/ansys/v241/fluent/fluent24.1.0/cortex/lnamd64/cortex.24.1.0 -f fluent -g (fluent "2d -pshmem -host -alnamd64 -r24.1.0 -t1 -mpi=intel -path/cm/shared/apps/ansys/v241/fluent -ssh")
Opening input/output transcript to file "/tmp/fluent-20240711-124434-2791956.trn".
Auto-Transcript Start Time: 12:44:34, 11 Jul 2024
/cm/shared/apps/ansys/v241/fluent/fluent24.1.0/bin/fluent -r24.1.0 2d -pshmem -host -alnamd64 -t1 -mpi=intel -path/cm/shared/apps/ansys/v241/fluent -ssh -cx viking-headnode.cm.cluster:42397:40375
Starting /cm/shared/apps/ansys/v241/fluent/fluent24.1.0/lnamd64/2d_host/fluent.24.1.0 host -cx viking-headnode.cm.cluster:42397:40375 "(list (rpsetvar (QUOTE parallel/function) "fluent 2d -flux -node -alnamd64 -r24.1.0 -t1 -pshmem -mpi=intel -ssh") (rpsetvar (QUOTE parallel/rhost) "") (rpsetvar (QUOTE parallel/ruser) "") (rpsetvar (QUOTE parallel/nprocs_string) "1") (rpsetvar (QUOTE parallel/auto-spawn?) #t) (rpsetvar (QUOTE parallel/trace-level) 0) (rpsetvar (QUOTE parallel/remote-shell) 1) (rpsetvar (QUOTE parallel/path) "/cm/shared/apps/ansys/v241/fluent") (rpsetvar (QUOTE parallel/hostsfile) "") (rpsetvar (QUOTE gpuapp/devices) ""))"
Welcome to ANSYS Fluent 2024 R1
Copyright 1987-2024 ANSYS, Inc. All Rights Reserved.
Unauthorized use, distribution or duplication is prohibited.
This product is subject to U.S. laws governing export and re-export.
For full Legal Notice, see documentation.
Build Time: Nov 22 2023 10:07:21 EST Build Id: 10184
Connected License Server List:
Unexpected license problem; exiting.
Hit return to exit.
As per the above output, it doesn’t show any license server.
Do we have to provide any additional licensing information apart from exporting the environment variable at client machine where the linux version is installed..?
Thanks,
Ranga.
July 12, 2024 at 12:56 pm
randyk
Forum ModeratorHi Ranga,
You indicate you confirmed port connectivity to the "LMGRD" port.
Flexnet licensing also has a Vendor Daemon port would also require network connectivity.
This port is dynamic by default and you can identify the assigned port in the license log.
However, you can set it to a static value by editing the license file VENDOR line and appending "PORT=1056"
ex: VENDOR ansyslmd PORT=1056
Is there a reason why you are attempting to use environment variable ANSYSLMD_LICENSE_FILE?
You could create/modify the file /cm/shared/apps/ansys/shared_files/licensing/ansyslmd.ini with contents:
SERVER=1055@LicenseServerName
thanks
Randy -
July 12, 2024 at 5:32 pm
SubscriberHi Randy,
Thank you so much for your reply.
I’ve modified the contets of /cm/shared/apps/ansys/shared_files/licensing/ansyslmd.ini with contents:
SERVER=1055@LicenseServerIP.But still it runs into the same problem.
The licensing server is available at 1055 port and the windows version of Ansys works fine.
This is the first time we are setting up Ansys on Linux OS. Is there anything else we are missing to run “fluent”..?
Thanks,
Ranga.
July 12, 2024 at 8:20 pm
MangeshANSYS
Ansys EmployeeHi
since the windows version is working but failing on linux 2 things come to my mind
- license server might be windows and on same domain and thus firewall might not be blocking any ports. but it just might be blocking traffic from linux IPs ?
- secondly is LSB installed (Ansys installation guide lists all the libraries that must be installed on linux as prerequisites preferably before installing Ansys)
July 12, 2024 at 8:09 pm
randyk
Please run the following - does it display license server increments?
/cm/shared/apps/ansys/v241/licensingclient/linx64/lmutil lmstat -i -c 1055@LicenseServerIP
You can also try running the following to perform a test checkout of the specified license feature:
/cm/shared/apps/ansys/v241/licensingclient/linx64/ansysli_util -checkout ansys
thanks
Randy -
July 12, 2024 at 8:22 pm
SubscriberHi Randy,
Following is the output for the commands..
[root@viking-headnode linx64]# /cm/shared/apps/ansys/v241/licensingclient/linx64/lmutil lmstat -i -c 1055@137.148.142.33
-bash: /cm/shared/apps/ansys/v241/licensingclient/linx64/lmutil: No such file or directoryI ran it from the same directory where "lmutil" is installed. It is still unable to locate.
[root@viking-headnode linx64]# /cm/shared/apps/ansys/v241/licensingclient/linx64/ansysli_util -checkout ansys
ANSYS LICENSE MANAGER ERROR : Insufficient FlexNet Publisher (FNP) license count of Ansys Mechanical Enterprise are available for use, only 0 of the requested 1 tasks were available.ansys CHECKOUT FAILED
Please let me know your comments.
Thanks,
Ranga.
July 12, 2024 at 8:27 pm
randyk
I am suspecting you do not have LSB installed.
The following should respond with version information once LSB packages have been installed.
/cm/shared/apps/ansys/v241/licensingclient/linx64/lmutil -v
thanks
Randy -
July 12, 2024 at 8:35 pm
SubscriberHi Randy,
It's already been installed.
[root@viking-headnode linx64]# yum install *lsb*
Last metadata expiration check: 0:01:18 ago on Fri 12 Jul 2024 04:30:56 PM EDT.
Package lsb_release-3.2-2.el9.noarch is already installed.
Dependencies resolved.
Nothing to do.
Complete!Could you please share a document or link for installing Ansys with complete instructions..? I'll go ahead and try to reinstall it.
Thanks,
ranga.
July 15, 2024 at 3:55 pm
randyk
Please confirm - these two commands continue to fail:file /cm/shared/apps/ansys/v241/licensingclient/linx64/lmutil
'file lmutil' should result in:
/lmutil: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.18, stripped
'lmutil -v' should result in: Copyright (c) 1989-2023 Flexera. All Rights Reserved. lmutil v11.19.4.2 build 291863 x64_lsb
thanks
Randy -
July 16, 2024 at 3:51 pm
SubscriberHi Randy,
Thank you for your reply. Below is the output for commands..
[root@viking-headnode linx64]# file /cm/shared/apps/ansys/v241/licensingclient/linx64/lmutil
/cm/shared/apps/ansys/v241/licensingclient/linx64/lmutil: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-lsb-x86-64.so.3, for GNU/Linux 2.6.18, stripped[root@viking-headnode linx64]# /cm/shared/apps/ansys/v241/licensingclient/linx64/lmutil -v
-bash: /cm/shared/apps/ansys/v241/licensingclient/linx64/lmutil: No such file or directoryAnd below is the list of files and their permissions in the directory where "lmutil" is..
[root@viking-headnode linx64]# ls -al
total 18400
drwxr-xr-x 3 root root 112 Jul 11 11:24 .
drwxr-xr-x 3 root root 20 Nov 3 2023 ..
-rwxr-xr-x 1 root root 11414520 Nov 3 2023 ansyscl
-rwxr-xr-x 1 root root 5908688 Nov 3 2023 ansysli_util
-rwxr-xr-x 1 root root 3229 Oct 16 2023 LicensingSettings
drwxr-xr-x 4 root root 4096 Oct 16 2023 LicensingSettingsUtility
-rwxr-xr-x 1 root root 1506616 Sep 30 2023 lmutilThanks,
Ranga.
July 17, 2024 at 12:43 pm
randyk
The issue is related to the OS version and Flexera version.Apparently, the lmutil v11.19.4.2 is compiled against /lib64/ld-lsb-x86-64.so.3That's why you get "no such file" when you try to run it: The "interpreter" is missing.This Flexera release was shipped with ANSYS 2024R1 releases.ANSYS released a patch that provided lmutil v11.19.5.0 - that is compatible with RHEL 9 and Ubuntu 22.04
Please install the "ANSYS_2024R1.03_LINX64.tgz" Service Pack 3 for ANSYS 2024R1
or install the latest available release ANSYS 2024R2
thanksRandy
- The topic ‘Error connecting to license server’ is closed to new replies.
5884
1306
