December 23, 2022 at 4:36 amRuud BoonSubscriber
We updated this week from 2022R1 to 2022R2
We use Spaceclaim since 2017 version and always used the insert Symbol. we didn't have any problems with updating till now. All computers have the same problem. We cant place a symbol.
I tried already a lot of things.
- Symbol with only text.
- Make new symbol libary document instead of the old one.
- Place libary on the C drive instead of the netwerk.
- Did a fresh new installation
- Put off the pluginsIs this a bug or can i fix this?
Log file is showing this message:
No SpaceClaim updates available.
08:48:39: start load Y:SpaceClaim1 - 3D-Templatestest3.scdoc
08:48:39: ended load Y:SpaceClaim1 - 3D-Templatestest3.scdoc
Ansys PlugInMgr failed: Failed to create object 412c6df4-76f3-4aa4-8d47-abb223ff7954
File is Y:SpaceClaim1 - 3D-Templatestest4 - Alleen tekst.scdoc
08:48:49: start load Y:SpaceClaim1 - 3D-Templatestest4 - Alleen tekst.scdoc
08:48:49: ended load Y:SpaceClaim1 - 3D-Templatestest4 - Alleen tekst.scdoc
An exception occurred in the Execute method of UICommand 'SelectBlock_x_2_0': Value cannot be null.
Parameter name: def
Exception occurred: (System.ArgumentNullException) Value cannot be null.
Parameter name: def
Exception Traceback: at SpaceClaim.EvalContext.GetParent(IDefinition def)
at SpaceClaim.Block.get_Parent()
at SpaceClaim.BlockManager.GetBlockIndex(IBlock block)
at SpaceClaim.CoreCommandContainer.selectBlockCommand_Execute(Object sender, UICommandEventArgs e)
at SpaceClaim.UICommands.UICommand.OnExecute(Object sender, EventArgs e, Boolean calledFromTheApi)CAInit: 0
December 23, 2022 at 4:51 amRuud BoonSubscriber
Found this question it is the same.
https://discoveryforum.ansys.com/t/x2h0hm1/bug#y4h0h9s -
December 23, 2022 at 7:25 amCharudatta BandgarForum Moderator
Hello Ruud
Filed a bug ticket 760789. Will update on this post, as I hear back from the development.
Regards
- The topic ‘Error by insert Symbol from libary’ is closed to new replies.
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Temperature’s Distribution not available in Refine Mode ?
- Issue Seeing Explore
- Warning Plugin Error Geometry in Design Modeler
1301
591
569
524
366
