January 20, 2025 at 6:31 am
Shin
SubscriberHello ANSYS Support,
I am encountering some issues during my simulation and need your assistance, as I couldn’t find similar problems or solutions online. At the beginning of my simulation, the time step is 1.0e-5. However, as the simulation progresses and H2 injection into the intake begins, the time step gradually decreases to 1.0e-12. After running for a while, the simulation stops automatically with an error indicating excessive recycling and a very small time step.
I have attempted to adjust the time step, but the same error persists. Could you please provide me with some advice? Thank you.
February 3, 2025 at 5:28 pm
jcooper
Ansys EmployeeHi Shin:
H2 Chemistry is very stiff. The reaction zone for h2 is much thinner than for other fuels, so the mesh and timestep requirements are stricter. You could try the same simulation with 1 deg per timestep, but this will not be enough if the mesh is too coarse.Â
Another thing to check is your refinements. Things often start to go wrong long before the solver fails. If you know when the simulation will fail, run it again and set it to stop just before the failure. Post process the solution for clues on where the mesh may be insufficient to resolve temperature and species gradients.
Best Regards,
Judy
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Script Error
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- convergence issue for transonic flow
- Running ANSYS Fluent on a HPC Cluster
- Point exception in erosion calculation
1937
839
599
591
366
