November 21, 2017 at 2:29 am
November 23, 2017 at 7:33 am
Min Zhang
SubscriberYour question is a little vague. Do you want to get a value which is the maximum between "Cbulk" and "(0.05[mm]-wall distance)*Salt flux/DiffCoeff+Cbulk" ?
If you cannot get that using the expression, maybe you can try to call a User Cel Fortran function.
November 24, 2017 at 12:18 am
Jimmyhan
SubscriberThank you for your reply, As you know, there is the explanation in ANSYS HELP which talks about how to write this kind of expression. But I can find them all. I mean I want to learn all kinds of expression syntax. I dont know how to use Fortran I just know its name. it should be some lists or function recommendations, right?
November 26, 2017 at 1:21 am
November 26, 2017 at 6:51 am
Jimmyhan
SubscriberThank you so much! You always give me such great help.
November 28, 2017 at 2:14 am
Viewing 5 reply threads
- The topic ‘Equation input’ is closed to new replies.
1330
1147
