January 3, 2019 at 4:29 pm
FrankR
SubscriberDear Community,
happy new year.
I use FLUENT "Academic Student Release" 19.2 on a Windows-PC.
I try to get output via "Export to CFD-Post", but the message
Unable to launch CFD Post from (path not fully displayed, ending in .../CFD-Post/bin/cfx5post.exe)
Please set environment variable CFX5ROOT and try again.
pops up.
Strikingly, I find cfx5post.exe only in a different path:
C:prgANSYS IncANSYS Studentv192CFXbin
I am a computer moron and our system administrator is still on holidays.
How can be problem be fixed ? Where and how do I have to set the environment variable ?
I am aware that I can disable the Open CFD-Post option, and load the file manually. Would be nice though.
Your kind assistance is greatly appreciated.
Regards
FrankR
January 3, 2019 at 8:12 pm
tsiriaks
Ansys EmployeeHi FrankR,
Normally, you should not need to set any extra environment variable.
I think there is something off here with the installation.
Since I don't see the full path that it's trying to launch /CFD-Post/bin/cfx5post.exe , I don't know if this is under the same parent directory as C:prgANSYS IncANSYS Studentv192CFX
Check this, open CMD Prompt, then type
set a
then, see if your ANSYS192_DIR and AWP_ROOT192 are pointing to the correct path (e.g., ANSYS192_DIR=C:prgANSYS IncANSYS Studentv192ANSYS and AWP_ROOT192=C:prgANSYS IncANSYS Studentv192
Thanks,
Win
January 4, 2019 at 8:45 am
FrankR
SubscriberDear tsiriaks
thank you. On the command prompt I get
H:>set a
ALLUSERSPROFILE=C:ProgramData
ANSYS192_DIR=C:PrgANSYS IncANSYS Studentv192ANSYS
ANSYS_SYSDIR=winx64
ANSYS_SYSDIR32=win32
ANS_OLD_ATTACH=1
AWP_LOCALE192=de
AWP_ROOT192=C:PrgANSYS IncANSYS Studentv192
cfx5post.exe resides in
cfx5post.pl resides in
C:prgANSYS IncANSYS Studentv192CFXbinperllib
Do you have any other advice ?
Do not invest too much brainwork: I am aware that I can disable the Open CFD-Post option, and load the output file from FLUENT manually.
Thanks once more,
Regards
FrankR
January 4, 2019 at 11:13 am
DrAmine
Ansys EmployeeCan you launch CFD-Post in Standalone?
January 4, 2019 at 1:34 pm
FrankR
SubscriberÂ
yes
Regards
Frank
January 4, 2019 at 9:23 pm
tsiriaks
Ansys EmployeeHi Frank,
On the shortcut that you used to launch stand-alone CFD-Post, right click -> Open file location -> right click on the shortcut and select 'Properties'
Post the content of the 'Target' here.
Also try this, open CMD Prompt then use this command
move %appdata%Ansys %appdata%Ansys.old
does this make any difference ? If not, post the output of
set c
Thanks,
Win
- The topic ‘environment variable CFX5ROOT’ is closed to new replies.
5834
