June 13, 2023 at 1:07 pm
Paul-Adrian Oprea
SubscriberI am simulating an axial turbine stage with a cooled stator and a rotor. The stator has holes inserted in SpaceClaim and then meshed and coupled with rotor TurboGrid into CFX. I defined the interfaces for the cooled air (air volume-blade; blade-segment volume and air volume-segment volume) and I defined the cooling air inlet with 0.05 kg/s and 850 K. The problem is that I get 99.8% efficiency which is impossible because I also simulated the turbine without the cooling holes and I have ~87% efficiency. The residual monitor for efficiency goes down to 98 and then rises again up to 99.8 where it converges. I work with a variable mixture fluid. I ran out of ideas of how to solve this problem, can someone give me a hint? The thing is when I change the temperature for the cooled air up to the same temperature of the fluid inside the turbine, the efficiency drops, but the point is to cool the blade.
June 16, 2023 at 2:11 pm
C N
Ansys EmployeeHello Paul,
I need more information on why you are getting this high efficiency . Please send some screenshots related to the boundary conditions and set up filesÂ
Thanks
Chaitanya Natraj
- The topic ‘Efficiency too high for turbine’ is closed to new replies.
3792
1388
1188
1095
1015
