July 13, 2020 at 8:39 am
Emmanuel001
SubscriberHi, I have Ansys ED 2020R1. I am using it to analyse my motor. My problem is how to activate the toolkit inorder to use it to calculate the efficiency map. I need a detailed procedure on how to locate the toolkit in Ansys ED 2020R1 -
July 17, 2020 at 2:39 am
Navya Chode
Forum ModeratorHello,
Here is the procedure to activate the machine toolkit.
Once you are on Maxwell >View>ACT extensionsÂ
On the pop-up window select Manage extensionsÂ
In the next window, you will see various extensions.
Select the Machine toolkit to add it to the wizard.Â
Now go back and launch your wizard and fine Machine toolkit.
July 17, 2020 at 1:26 pm
Emmanuel001
SubscriberThank you Sir for the procedure. I have seen the toolkit. Can you recommend any Ansys guide document on how to use the machine toolkit in getting efficiency map cos I am getting error message if I initiate it. -
July 17, 2020 at 3:34 pm
July 20, 2020 at 12:52 am
Emmanuel001
SubscriberHi, Thank you sir for your help so far. I have done exactly how you instructed. The simulation is running now, but my problem is how will I view the results when the simulation is completed? -
July 20, 2020 at 8:37 am
July 25, 2020 at 4:20 am
Emmanuel001
SubscriberThank you Sir. I followed all the steps religiously and it gave me what I wanted. I so appreciate for your help!!!
Viewing 6 reply threads
- The topic ‘Efficiency Maps of motor’ is closed to new replies.
1311
