August 14, 2023 at 10:29 amJoonseong LeeSubscriber
I am calculating the stress intensity factor for internal cracks in a pressure vessel. When calculating the stress intensity factor with the following settings, the quality of the stress intensity factor in the corner area is poor. How can I properly view the stress intensity factor for axial cracks? should?
August 18, 2023 at 1:33 pmAshish KhemkaForum Moderator
Can you try increasing the number of divisions in the circumferential direction?Â
Ashish Kumar
August 21, 2023 at 2:37 pmDavid WeedAnsys Employee
Hi Joonseong,
Can you show a more descriptive picture of the crack mesh? Perhaps at a different angle which shows how the crack is situated on the topology of the body (please show crack mesh). Thanks.
- The topic ‘Edge quality of stress intensity factor’ is closed to new replies.
Ansys Innovation Space
- Ayuda con Error: “Unable to access the source: EngineeringData”
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- How to select the interface delamination surface of a laminate?
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- SMART crack under fatigue conditions, different crack sizes can’t growth
- Frictional No separation contact
591
544
524
366
