    • mtalha976
      My input in DPM :nTotal mass: 7.7mg over a distributed source from surface injectionnStop time : 0.12nTotal Number of particles : 1008nDiameter : Not uniform.nSo my question How can i give total mass , total number of particles and Distribution source in DPM?nI am stuck in thisnThanks.n
      You assign a mass flow rate, so set the start and stop times to give the correct amount of material. Size distribution is set in the injection. n
    • mtalha976
      Sir I dont know what value should I give to mass flow rate or how it is calculated from total mass . nn
      You add a mass over a set time, which you can then work out the mass flow rate. If I want to add 10kg of material I could add 10kg/s for one second, or 20kg/s for half a second. n
  • The topic ‘DPM Mass’ is closed to new replies.
