January 7, 2022 at 10:18 am
Abelz
SubscriberHello, I'm trying to model a 3D numerical wave tank with a perforated wall type breakwater with toe at bottom front of the perforated wall.
What are the boundary conditions that should be given for wave generation in this case. Â I'm using ANSYS 2021 R2 (Teaching).
Thanks in advance.
January 7, 2022 at 11:07 amRob
Forum ModeratorI'd use the open channel boundaries via VOF and then flow boundary conditions. However, I'd also question the need for the solid zones as we're only modelling the "wet" bits and don't need any solid parts unless you're also looking at heat transfer or FSI.
Viewing 1 reply thread- The topic ‘Doubt regarding boundary condition’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- How do I get my hands on Ansys Rocky DEM
- Script Error
- convergence issue for transonic flow
- Running ANSYS Fluent on a HPC Cluster
- Point exception in erosion calculation
- Errors with multi-connected bodies using AQWA
Top Contributors-
1997
897
599
591
444
