March 29, 2022 at 11:40 amnepSubscriber
I attachment the results that i have in a process steady-state . With this results (unchecked residual checks) the residuals appear stable and the temperatures appear that it looks like they are going to continue like this. My doubt is:
With these results, can I consider that the model is correct?
Can I consider that the process has stabilized and is stationary?
March 29, 2022 at 1:59 pmNikhil NAnsys EmployeeHello,
Ansys employees are not allowed to download any attachments from here. Can you please post the screenshots in the comment section directly?
Nikhil
March 29, 2022 at 2:03 pmMarch 29, 2022 at 2:37 pmRobForum ModeratorYou had attached the images, we're having problems loading stuff on this side. I think IT are messing with things they shouldn't....
The residuals aren't converged, but suggest the solution isn't changing much. However, as the monitors are still changing I wouldn't trust the results. Are you monitoring any other points, and velocity anywhere?
March 30, 2022 at 9:45 amnepSubscriberMy system was a steel plate to which solar radiation is incident. I have also simulated the heat transfer which is the second variable I'm interested in after the plate temperature, and it seems that the heat transfer is stable, I introduce image:
Do you think my model would be correct?
Maybe the temperature should stabilize horizontally as it's steady state, but on the other hand FLUENT does not stop radiating 887 w/m2 , so it would be logical that the temperature continues to increase as in the first graph I think...
Could you help me please? to know if it's right.
Thank you very much for your help
March 30, 2022 at 11:03 amRobForum ModeratorI think it's still converging - the lines look flat as they're not changing much. Give it another few hundred iterations and review then.
March 30, 2022 at 12:54 pmMarch 30, 2022 at 1:09 pmRobForum ModeratorUntil it stops changing. Have a look at the flow and temperature field to see what's going on.
Viewing 7 reply threads- The topic ‘Doubt of stability, convergence and steady-state.’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- convergence issue for transonic flow
Top Contributors-
1727
630
599
591
366
