Display Element ID
    • Yalcin Sevimay
      I want to trace an error. I want to know the element location, could you please help me.
      Create a Named selection using the Worksheet. Type the element ID in the Value column.
    • Yalcin Sevimay
      Thank you. let me see
    • Sampat Kumar
      As Peteroznewman mentioned, you can create a named selection and see the corresponding element ID.  In addition to this, you can follow the steps that I explained below to find the element ID as well.
      1. Click on the select by option–> select mesh by ID–> select the element option --> enter the element ID there and then click on the select. you will able to find the corresponding element. you can find the option there also to create the name selection corresponding to the selected element.
      Sampat
      /forum/forums/topic/guidelines-for-posting-on-ansys-learning-forum/#latest
    • Yalcin Sevimay
      Guys I am very happy getting answer from here. I am sorry I can not say thank you in time. cheers
    • Sampat Kumar
      Welcome!
      Happy to help you ?.
      Sampat
Viewing 5 reply threads
  • The topic ‘Display Element ID’ is closed to new replies.
