November 20, 2024 at 9:44 am
ph23resch01002
SubscriberDear Sir/Madam,Â
I have used the s params analysis group, to calculate the s and s polarization and transmission coefficients. When I use the transmission monitor, I get a plot as shown below
Then, I have used the result S from the s_params analysis group to calculate the T for the x polarised incidence. I have done the abs(s12)^2, I got the following plot,
 As far as I know, if we have to measure the transmission coefficients, we must do the abs(S_12)^2. But why do I get such a discrepancy? Can you shed some light on it?
Thank you.ÂÂ
November 20, 2024 at 6:01 pm
Amrita Pati
Ansys EmployeeHi,
Yes, I believe the results should be the same. Is the resolution of data/number of points used to plot the graph in both cases same?
Amrita -
September 30, 2025 at 4:00 pm
jonathan.atkinson
SubscriberIs there a solution to this discrepancy? I am having the same issues in a simulation. The data points are the same. Â
